Bottlehead Kits
Legacy Kit Products
Quickie
Choke loading question
xcortes
4507
xcortes
Sr. Member
December 20, 2016, 05:48:07 AM
I want to try some EXO-001 chokes in the Quickie. They are 1k ohm so the plate of the tubes would be at higher voltage than designed. Is that OK or should I do other changes to adjust the operating point?
Thanks a lot!
Xavier Cortes
Global Moderator
Hero Member
Re: Choke loading question
Reply #1 on:
December 20, 2016, 09:59:34 AM
It's OK. The operating conditions are stabilized by the cathode resistor. You will draw a bit more current so the 9-v batteries will drain faster, but probably not enough to be noticeable.
xcortes
Sr. Member
Reply #2 on:
December 20, 2016, 12:08:02 PM
Cool. Thanks Paul!
Xavier Cortes
BNAL
Sr. Member
Reply #3 on:
December 20, 2016, 12:19:03 PM
xcortes,
I'm interested to know what you think of the chokes in the Quickie. I just received mine in the mail and having some upgrade options would be great.
Brad
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
xcortes
Sr. Member
Reply #4 on:
December 20, 2016, 01:10:50 PM
I''m sure the pjccs are better but I'' planning to build an pre+ headphone amp quickie with a lot of parts available. It's gonna be a monster for my earbuds
Xavier Cortes
johnsonad
Hero Member
Reply #5 on:
December 20, 2016, 01:31:55 PM
sounds like you are putting that extra MQ iron to good use my friend!
xcortes
Sr. Member
Reply #6 on:
December 20, 2016, 01:45:55 PM
At least part of it
Xavier Cortes
Bottlehead Kits
Legacy Kit Products
Quickie
