Speedball Voltage Check Issue [resolved]
M42 · 5547
Reply #15 on: January 09, 2017, 05:58:19 AM
I would pull the Speedball and put the resistors back. There's an issue with the underlying build that needs to be resolved first.
Offline M42
Reply #16 on: January 15, 2017, 07:26:01 AM
I reinstalled the two resistors. I could not find the identical value (22.1 kohm), I've used NTE 1/2 watt 22 k ohm, 2% in their place.
Resistance:                                        Voltages:
1     .378 m ohms                               91.5
2     .342 m ohms                               229
3     0                                                0
4     .329 m ohms                               228
5     1.06                                            26
6     2500                                           0
7     3050                                           26
8     0                                                 26
9     2.95                                            0
10    2508                                          0
11    n/a                                            0
12   0                                                0
13   .635 m ohms                               0
14   0                                                0
15   n/a                                             233
20   0                                                0
21    n/a                                            238
22   01.5                                           a1   26                                     b1    90.6
b3   2950                                          a2    0                                      b2    230
b6   2953                                          a3    1.45                                 b3    26
rca ground jacks:                               a4    0                                      b4   26
ground lug    0                                   a5    0                                      b5   230
center pin     2502                              a6    90.7                                 b6   0
                                                         a7    0                                      b7   0
                                                         a8    1.56                                 b8   0
                                                         a9    0
Jeff Hullin
Stereomour(2A3), Eros, Crack/Speedball, Thorens TD160 MKII, Grace F9E, Sennheiser HD600's, Frugelhorn 3's, DIY 8" Subs.
If at first, the idea is not absurd, then there is no hope for it.
Reply #17 on: January 18, 2017, 09:41:24 AM
5     1.06
The amp should not be powered on again until we can determine what went wrong here.  Your last resistance reading was 3,000 Ohms, now it's 1 Ohm.  Neither resistance reading is correct.
I would be interested in seeing more photos of the build, as I might be able to spot the issue.
Offline M42
Reply #18 on: January 18, 2017, 10:04:59 AM
Thanks Paul...I'll put some up this evening.
Jeff Hullin
Offline M42
Reply #19 on: January 19, 2017, 01:50:00 AM
A few more photos of the amp...
Jeff Hullin
Reply #20 on: January 19, 2017, 09:59:09 AM
Pull the 6080 and power up the amp with just the 12AU7, then measure the voltages at 1 and 5 again.
Offline M42
Reply #21 on: January 20, 2017, 01:45:37 AM
Measured once more before pulling the 6080 tube:
led still out on 9 pin socket
terminal 1   92.4v
terminal 5   26.8v
6080 removed:
both led's lit on socket
t1   92v
t5   94.6
replaced 6080:
both led's lit
t1   78v
t5   80.5v
removed 6080:
both led's lit
t1   92.6v
t5   95.4v
6080 in:
both led's lit
t1   78v
t5   81v
I had the big tube out of the amp prior to this issue, but am certain it was correctly seated/oriented at the time of the voltage checks for the small board. It would appear I can reinstall the small board?
Jeff Hullin
Reply #22 on: January 20, 2017, 02:39:52 PM
If your keyway has broken off the 6080, and the tube was inserted off by just one pin's worth of rotation, that would explain 100% of the issues that you're having.
Offline M42
Reply #23 on: January 23, 2017, 01:42:38 AM
I do have an index mark on the tube, but despite that I must have reinstalled the tube incorrectly??? This appears to be the only logical explanation...a humbling lesson to be sure. I installed the large board without incident. Voltages measure:
OA  103.9V
OB  101.6V
G    OV
B+  174.5V
The 6080 tube now appears to be microphonic...I have ordered replacement tubes. I've had little time to listen to the amp, but I'm very happy with what I hear so far! Thanks very much for your help with this.
Jeff Hullin
Offline Tom-s
Reply #24 on: January 23, 2017, 02:13:10 AM
Leave Crack on for a while (a day continuous), might get rid of the microphonics.
Offline M42
Reply #25 on: January 23, 2017, 03:03:35 AM
Thanks Tom, I'll give that a try.
Jeff Hullin
