Kaiju Channel stops working momentarily
hbonilla · 2948
Offline hbonilla
on: January 20, 2017, 04:56:53 PM
I just finished upgrading my Kaiju with the DC filament supply and it sounds awesome. However after a few minutes of playing, maybe 5 or 10, the left channel stops working. So I tried turning it on and off and evrytime I do so the channel works again. Has anyone had the same issue?
Reply #1 on: January 21, 2017, 08:06:43 AM
You'll want to get a voltage check in when that channel has dropped.
Reply #2 on: January 21, 2017, 08:53:13 AM
Are you waiting after you turn it off, as in long enough for something to cool down? Or do you just switch off/switch on and it comes back? The latter would be more likely to be a bad solder joint. The former might be a not-optimal heat sink mounting.
Offline hbonilla
Reply #3 on: January 21, 2017, 07:46:19 PM
Yes it is actually the latter. A quick turn off and on will bring the channel back alive.
However, I let it rest through the night and have listened to it for three hours today and everything seems to be ok.
I will keep you posted.
H
Reply #4 on: January 26, 2017, 05:28:58 PM
OK, if it happens again I would first swap tubes from side to side and see if it follows one. If it stays in the same channel after the tube swap I would next look for a cold solder joint that might be expanding and losing contact when things get warmed up.
