Eros troubleshooting new build with low gain [resolved]
arri · 2467
Offline arri
Just finished a new Eros I'm building for a friend. Everything seemed like it was checking out (with some exceptions noted below) but when I replaced my old faithful Seduction with the Eros to feed a Crack amp from a Goldring G012 moving magnet cartridge the gain just wasn't there and what little sound there was had a kind of distortion. On the other hand, with no vinyl spinning, the noise floor was extremely low ;)
Voltages:
Terminal   A     B
Kreg      4.1   4.6
breg      136   140
OA        142   145
IA        223   223
bA        0     0
OB        137   140
Resistance Check (only listing where things were potentially out of bounds and all of the C socket):
TS   Read   Target
T2   85k   71k
T4   75k   60k
T9   47k   39k
T10  47k   39k
T12  75k   60k
T14  86k   71k
A4   620Ω    *
A6   75k   60k
B4   620Ω *
B6   75k   60k
C1   47k   39k
C2   75k   60k
C3   falling   *
C4   620Ω  inf
C6   47k   39k
C7   75k   60k
C8   falling   *
C9   0     0
The Kreg, breg, OA and OB all seem high but I can't figure out why. The power supply voltages all measured correctly. All of the LED's are lit although it takes a few seconds for the shunt regulator board to light up. Any electrolytics are facing the correct direction. I have gone back over everything and am not seeing anything glaring; frankly, I was pretty pleased with the quality of my assembly and soldering.
Any suggestions or requests for more info?
arri
« Last Edit: January 21, 2017, 08:07:35 AM by Caucasian Blackplate »
Offline arri
Reply #1 on: January 20, 2017, 06:57:16 PM
Looking over the C4S's again (for the n'th time) I think I located the problem. I installed the 2N2222A transistors on the A side instead of the B side of the board on both. Amazing because I deliberately told myself to (and did) build each board separately following the instructions each time so that I wouldn't replicate any mistakes. And yet I still apparently read it wrong both times!
Now to move the little bastards.
arri
Offline arri
Reply #2 on: January 20, 2017, 08:04:19 PM
Yup. That was it, Kreg came down to 1.8v. OA up to 164, and OB down to 96v. And now they sound good too!
Reply #3 on: January 21, 2017, 06:16:51 AM
Good job sorting it! This is one of those cases that explains why we suggest posting photos in these queries. More eyes on can usually spot misplaced parts pretty quickly.
