Final Voltage check Questions [resolved]
Why1504 · 2698
Offline Why1504
on: January 25, 2017, 04:23:09 AM
All of my readings were within 10% except the following.
TS   Expected     Actual
2        71K            84.3K
4        60K            73.8K
12      60K            74.1K
14      71K            84.6K
 Please advise on how I should proceed.
EDIT:  I have now reflowed ever terminal strip.  No change.
THANKS!!
« Last Edit: January 26, 2017, 01:06:25 PM by Caucasian Blackplate »
Offline Why1504
Reply #1 on: January 25, 2017, 10:27:43 AM
OK, I looked forward thru the form and saw where another got similar readings and that it was OK.
I proceeded to check the resistance for the sockets. I had some readings there that were also high which I also assume are good.  However pin 4 on scokets A, B, and C all return a value of .621K
I think this is a problem.  Can someone in the know please advise.
Offline Why1504
Reply #2 on: January 25, 2017, 11:00:47 AM
OK,
I re-read this post:
http://bottlehead.com/smf/index.php?topic=8858.0
He had the same reading so I proceeded to the Voltage Check.
Everything was within a few volts except OB on one board (100vdc expected)  I got 45.6vdc
Please advise.
Offline Why1504
Reply #3 on: January 25, 2017, 11:26:10 AM
I just re-flowed all of the connections on the card in question.  No change.
Offline Why1504
Reply #4 on: January 25, 2017, 12:19:17 PM
FIXED!!
All the voltages are a bit low but close.  About to make some music!!
Offline Why1504
Reply #5 on: January 25, 2017, 12:57:30 PM
Sound is nothing short of breathtaking.
