Quickie Mod Advice
brucef · 5668
Offline brucef
on: February 06, 2017, 08:34:07 AM
Really liking this little pre. Have been listening to it for a couple of weeks. Thinking about upgrading the 150uf 16v cap and the 2.2uf cap. I have noticed a few people have talked about using a Black Gate for the 150uf. Since they are no longer manufactured, I could not find one with the same value as the one that is currently in the Quickie. What value would be acceptable? Or would another brand be better to try? Also looking for suggestions / recommendations for the 2.2uf cap.
Bruce F
Reply #1 on: February 09, 2017, 07:39:16 AM
There are loads of different electrolytic caps you can try in the Quickie.  I believe the smallest value you want is something like 47uF, and the highest value is whatever will fit under the chassis.  DC voltage rating should be 6V or higher.
On the 2.2uF cap, there's also some allowable variation there, but I would recommend staying over 1.5uF.  Any film cap that you find is going to have an acceptable voltage rating.
Offline brucef
Reply #2 on: February 10, 2017, 03:29:32 AM
Thanks PB!
Bruce F
Offline aragorn723
Reply #3 on: March 25, 2017, 07:14:18 AM
If you'd like to try black gates, check out the link below:
http://www.thlaudio.com/bgcapitme.htm
Offline BNAL
Reply #4 on: March 25, 2017, 10:04:00 AM
I would suggest upgrading the pot. I use the eBay 21 step DACT step attenuator.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline brucef
Reply #5 on: March 27, 2017, 05:59:14 AM
Thanks for the suggestions. I did replace the 150uf caps with some Black Gate and the 2.2uf caps with some Mundorf Supremes.
Bruce F
Offline aragorn723
Reply #6 on: March 27, 2017, 05:02:30 PM
FWIW in my experience the black gates opened up the upper end treble.  I think that part was what really made me love the Quickie besides the PJCCS and changing output caps.  Happy listening!
Dave
