Input Transformer Question
Alonzo · 6619
Offline johnsonad
Reply #15 on: May 07, 2017, 12:33:27 AM
Good idea and keep us updated.
Offline Alonzo
Reply #16 on: May 17, 2017, 05:50:10 PM
Mid May update.  The transformers input gets more and more play.  I needed to even the playing field so I have Harrison attenuators on the amp to make the levels closer on the transformer and non transformer inputs.  Each input sounds good, but I keep coming back to the transformers each night.  Another couple of weeks and the BeePre will go back to the bench for the final changes.
Alonzo
Offline Alonzo
Reply #17 on: May 27, 2017, 08:08:00 PM
End of May update.  Everything's great with the BeePree, loving the input transformer sound.  Only issue remaining is the gain I have feeding my amps.  12dB attenuators at the input of the amps hasn't helped, I only have 1/8 the range on the pot.  Need to research how to attenuate the preamp since I like the level the amps are.   Must have made a mistake when installing the P&G pot cause I can't imagine everyone only using the first eighth of the pot only.
No microphonics at all with the current EH 300b's, have removed the lead weights completely.
Alonzo
