Bottlehead Kits
Legacy Kit Products
Foreplay III
Adding mono switch
Adding mono switch
ga-wise
6285
ga-wise
Newbie
Adding mono switch
March 10, 2017, 05:22:24 PM
Scanning this forum I've found two suggestions for adding a mono switch to the Foreplay:
1. Connect terminals C & D of the input switch to a SPST switch.
2. Connect output of volume controls to SPST switch. This method apparently may not work as well at full volume.
Is either of these considered best or is there yet another even better way?
Paul Birkeland
Global Moderator
Hero Member
Re: Adding mono switch
Reply #1 on:
March 13, 2017, 06:51:41 AM
I would opt for the connection at the selector switch, as I believe there's a little more space up there, and it leaves some flexibility for the time down the road when you might want to change out your attenuators.
ga-wise
Newbie
Reply #2 on:
March 15, 2017, 05:06:32 PM
Thanks PB, sounds like a plan...
Bottlehead Kits
Legacy Kit Products
Foreplay III
Adding mono switch
