Bottlehead Kits
Crack
Smoke before voltage tests
Fosu
2178
Fosu
Newbie
April 05, 2017, 05:12:28 AM
Hi guys!
If I plug power on the transformer will start to smell and smoke. Leds doesn't light up either but tubes will glow. All the resistance checks did pass.
I did try to solder all the questionable joints once again but problem still continues.
I tried to get several pics so you can see my soldering.
I'm living in Finland and incoming voltage is 230V.
fullheadofnothing
Global Moderator
Hero Member
A noble spirit embiggens the smallest man
Re: Smoke before voltage tests
Reply #1 on:
April 05, 2017, 07:04:04 AM
The 4007s on the outboard side of the terminal strip are reversed.
One should have
a banded lead pointing to 19 and unbanded to 20
and
unbanded lead pointing to 19 and banded to 21.
You have
an unbanded lead pointing to 19 and banded pointed to 20
banded lead pointing to 19 and unbanded pointed to 21
Review pages 38 and 39 in the manual.
Fosu
Newbie
Reply #2 on:
April 05, 2017, 08:00:09 AM
Oh my...
I now changed those 4007s as it is in manual. Did the resistance check and those passed once again.
Tried once again with power on: leds started just like my hope but then transformer started to smoke and leds went off with my hope.
fullheadofnothing
Global Moderator
Hero Member
Reply #3 on:
April 05, 2017, 08:38:47 AM
It sounds like you have damaged your power transformer. Contact replacementparts at bottlehead dot com to order a replacement.
Fosu
Newbie
Reply #4 on:
April 06, 2017, 03:13:46 AM
Well f...
Thank you for your help! I send an email to that address.
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
April 06, 2017, 01:41:45 PM
Just to be sure, you can remove the wire that connects to terminal 11 on the power transformer, then do a glow test on the amp and see if anything is getting warm.
Fosu
Newbie
Reply #6 on:
April 11, 2017, 07:58:03 AM
I removed the wire and did the test. Both tubes will start to glow and after a minute the power transformer will start to smoke and smell.
I already ordered a new power transformer and now waiting that to arrive.
Bottlehead Kits
Crack
