Crack - Speedball Voltages - no sound left channel (resolved)
ostoich · 3488
Offline ostoich
I know the manual says that being off by a few % isn't a big deal. I just want to make sure before I turn this puppy loose.
All voltages were within suggested range for the small board. The big board was a bit higher:
OA - 135v
OB - 120v
G - 0v
B+ - 206v
Everything look good?
Thanks for all the support.
« Last Edit: April 23, 2017, 02:21:28 PM by ostoich »
Eric Ostoich
iMac -> Schiit Bifrost -> Bottlehead Crack w/Speedball -> Sennheiser HD650
Rega RP3 -> Bottlehead Reduction w/Integration -> Yamaha S501 -> Energy RC-70
Offline ostoich
Reply #1 on: April 10, 2017, 07:03:22 PM
Well it sounds great in the right channel...
Nothing in left channel. Bummer. Back to work tomorrow I suppose.
Eric Ostoich
Offline calmiswar
Reply #2 on: April 10, 2017, 10:47:36 PM
DO NOT connect your good headphones into the amp right now.
I destroyed my HD700s doing that, don't make the same mistake.
Offline ostoich
Reply #3 on: April 11, 2017, 01:10:49 AM
Right. I unplugged them right away. Tried taking some cheapies to find a loose connection with chopsticks. Couldn't find anything last night.
Eric Ostoich
Online Paul Birkeland
Reply #4 on: April 11, 2017, 11:50:18 AM
What are the small board voltages?
Offline ostoich
Reply #5 on: April 11, 2017, 12:47:46 PM
Small board:
OA - 78V
IA  - 202V
B-A/B - 0V
IB - 202V
OB - 78V
Eric Ostoich
Offline ostoich
Reply #6 on: April 13, 2017, 06:46:39 AM
The most noticeable thing is that the TIP50 on O2B runs hot and O2A stays cool. I suppose I'll focus on that side of the board. Any other thoughts about what might be wrong?
Eric Ostoich
Reply #7 on: April 13, 2017, 12:12:13 PM
Yes, I would agree that focusing on that side of the big PCB is a good idea.  It could be as simple as a bad solder joint that isn't allowing adequate current draw.  Since you have Speedball 1.1, the R1 resistors are where they should be, and the PN2907 and 2N2222 are impossible to mix up (your small board is also working, which excludes these possibilities).
I would bet on the center leg of the TIP50 on the offending side not being soldered well enough.
Offline ostoich
Reply #8 on: April 13, 2017, 05:00:05 PM
Resoldered all leads of the TIP50. The soldering iron caused a spark on the lead closest to the center of the board. Now the LEDs on the A side of the board won't light. Thoughts?
Now I'm running:
OA: 196V
B+: 202V
OB: 120 V
G: 0V
What did I break? I'm​ a total novice but I thought the instructions were so clear that there was no way I could mess this thing up.
« Last Edit: April 13, 2017, 05:09:23 PM by ostoich »
Eric Ostoich
Reply #9 on: April 14, 2017, 08:24:00 AM
How are your voltages at 6 and 10?
Offline ostoich
Reply #10 on: April 14, 2017, 12:13:39 PM
Both terminals 0V.
Eric Ostoich
Reply #11 on: April 14, 2017, 02:20:54 PM
I would suggest replacement of the TIP50 and the 2N2222 on that side of the big PCB.  A spring-loaded solder sucker makes this work much easier.
Offline ostoich
Reply #12 on: April 16, 2017, 09:45:05 AM
Ordered these from Mouser. Will they work or should I email replacement parts?
TIP50: http://www.mouser.com/Search/m_ProductDetail.aspx?r=512-TIP50
2N2222A: http://www.mouser.com/Search/m_ProductDetail.aspx?r=494-2N2222A
Sadly, I'm feeling a little impatient because of how close I am to finishing.
Eric Ostoich
Reply #13 on: April 19, 2017, 01:34:40 PM
You don't need to spend $6 on a 2N2222 transistor, Mouser # 610-2N2222  will do the job nicely.  The TIP50 selection you made is a good choice.
Offline ostoich
Reply #14 on: April 22, 2017, 10:13:50 AM
So, I replaced the TIP50 and the 2N2222. LEDs still don't light on the A side of the big board. B side LEDs lights up fine after about 10 seconds. The 270ohm resistor from T15 to T21 also gets really hot... Really fast. Voltages are now:
Large Board:
OA - 55V
OB - 79V
B+ - 89V
G - 0V
Small Board:
OA - 77V
IA - 88V
B-A/B - 0V
IB - 88V
OB - 51V
I just removed the entire big board and will resolder every joint. Then try reinstalling it. Wish me luck.
« Last Edit: April 23, 2017, 04:41:57 AM by ostoich »
Eric Ostoich
