Extended FP III Shunt Reg problem
pdxgrampa · 35634
Offline pdxgrampa
on: November 04, 2017, 10:10:56 AM
This is not a new build has been in service off and on for a few years.
It would drop out briefly and then recover and then failed completely.
A side LEDs were on B side not then A side LEDS were off but MJE 350 was conducting.
H1: 24.5 VOLTS
H2: 29.4 VOLTS
A SIDE HIGH VOLTAGE                              B SIDE HIGH VOLTAGE
7:   223   VOLTS                                                  7:    222   VOLTS
9 :  213   VOLTS                                                  9 :   221   VOLTS
10; 204   VOLTS                                                 10:   221   VOLTS
TERMINAL
12: 116 VOLTS
15:  78  VOLTS
21: 115 VOLTS
22:  21  VOLTS
31: 78   VOLTS
32: 115 VOLTS
Greg
Music Hall 5.1SE,EROS. OPPO 980HD, Music Hall 25.3 Dac. BeePre/BeeQuiet. Paramount V1.1 300B,Orca Deluxe W/ Subs/SPA250s.Stereomour W/Orca Deluxe. Crack W/Speeball(2) .Beyerdynamic 990s.Crackheadphone.
Reply #1 on: November 04, 2017, 06:29:00 PM
Are you able to post photos of the PC boards?
For the most part, on just about every Extended Foreplay III that I have serviced that was initially in working order, I end up building a new center PC board for the high voltage shunt regulator.
It's very easy to see if this is the issue, as the center board you have now will be a bit black under where the MJE-350s each sit.
Offline pdxgrampa
Reply #2 on: November 05, 2017, 03:11:54 AM
This the B side MJE 350
Greg
Reply #3 on: November 05, 2017, 04:25:35 AM
Can you tell me what voltages you get at:
1.  The metal tab of each MJE-350 on the center board.
2.  Kreg A and Kreg B on the center board.
3.  The metal tab of each MJE-350 on the outer boards.
4.  The metal tab of each MJE-340 on the outer boards.
Offline pdxgrampa
Reply #4 on: November 05, 2017, 04:45:27 AM
Paul here is what you asked for:
All voltages referenced to terminal 18
The voltages on the side MJE 350s and 340s are all 78 volts
Tab on A side shunt reg board 350 is 117 volts dropping slowly from 123 at first measurement.
Tab on B side is 116 down from 126
A side Kreg is 0 volts
B side Kreg  7.5 volts
Greg
Offline pdxgrampa
Reply #5 on: November 05, 2017, 05:31:16 AM
Doesn't look like picture made it .
I'll try again
Greg
Reply #6 on: November 05, 2017, 06:46:07 AM
Pull the outer two 12AU7s and retest the center PC board.
(Also, the MJE340 tabs should be a volt or two higher than the MJE350 tabs on the outer PC boards when all the tubes are plugged in and running)
« Last Edit: November 05, 2017, 08:19:20 AM by Caucasian Blackplate »
Offline pdxgrampa
Reply #7 on: November 05, 2017, 07:28:57 AM
Ok tubes out:
 A side                                 B Side                              Shunt Reg
350: 146.8 volts                  350: 146.8                        A side 350: 149
340: 150.9                          340: 150.0                        B side 350: 148.5
        A side Kreg; 0
        B side Kreg: 8.72
Greg
Reply #8 on: November 05, 2017, 08:20:28 AM
        A side Kreg; 0
        B side Kreg: 8.72
It's odd that the A side Kreg is stuck at 0V but the regulator appears to work.  With 0V available for the TL431 to operate, I would expect your regulated voltage to be just a volt or two less than your unregulated voltage.
Offline pdxgrampa
Reply #9 on: November 05, 2017, 10:51:25 AM
PB,
Unless there is something else to measure/try
Should I just contact the Queen on Monday for a board and Parts?
Thanks for your help
Greg
Greg
Reply #10 on: November 05, 2017, 03:33:25 PM
That particular PC board is NLA, and several of the parts are also no longer stocked in our inventory.  There are some workarounds for this situation; feel free to contact me and we can go over the options to get you back up and running.
Offline pdxgrampa
Reply #11 on: November 05, 2017, 04:54:43 PM
Thanks Paul,
 I didn't see a way to PM you.
 so I will call the store on Monday if that works for you.
Greg
Greg
Reply #12 on: November 06, 2017, 03:55:49 AM
You can e-mail me at pb(at)bottlehead(dot)com.
Offline pdxgrampa
Reply #13 on: November 06, 2017, 06:37:30 AM
Will do Paul
Greg
Greg
