Problems with headphone jack when tightened [resolved]
rlX · 1746
Offline rlX
Hey there,
I've built my Bottlehead Crack with the Speedball Upgrade a couple months ago and really like it. I only have one problem, that i couldn't find a thread for in this forum. Whenever I tighten my headphone jack onto the chassis, i get really loud noises kind of comparable to this: youtube.com/watch?v=7elhadWF6U0
However, when I make sure, the headphone jack sits loose on the chassis I am not facing this problem. I just rechecked, that i wired everything correctly, I have resoldered most of my soldering spots, I have done the stick test to check for bad soldering spots with no success.
Does anyone have an idea what could be the cause of this?
Best regards,
Jonas
« Last Edit: November 16, 2017, 04:07:35 AM by Caucasian Blackplate »
Reply #1 on: November 12, 2017, 06:16:59 AM
If the position of the headphone jack creates noises, you have a flaky solder joint.  The solder joint where the black wires join on the headphone jack is one that can sometimes be tough to solder properly.
Offline rlX
Reply #2 on: November 16, 2017, 01:41:35 AM
This solved my problem, thank you very much!
