Correct transformer voltage settings
Kitchener · 2390
Offline Kitchener
    • I made something!
on: February 14, 2018, 11:55:41 PM
I’ve been reading the Crack manual (kit is in the mail!).
And I’m quite uncertain what voltage settings I should use for my Crack.
Our national power grid is supposed to deliver 230 Volts, but this can vary up to 10% either way.
I could measure the voltage in my house and set the transformer according to that, but I intend to use the Crack at my office as well.
So considering that the voltage in my house and my office could potentially vary a bit, what setting should I use for my transformer?
Should I use the “GREATER than 225V AC and LESS than 235V AC” setting?
Modded, Speedballed Crack + Sennheiser HD6XX
STAX SRM-353X + SR-L500
STAX SRM-313 + SR-L300
-Jørgen E. J.
Reply #1 on: February 15, 2018, 03:58:03 AM
You should get a meter and measure the voltage at both locations.
Offline Kitchener
    • I made something!
Reply #2 on: February 15, 2018, 09:58:12 AM
Yeah but even so, what if both locations measure 230 Volts and that's fine for a while until I move it someplace where the voltage differs to a greater extent?
What are the risks of using a Crack attuned for 225-235 Volts in a socket with 210 or 240 Volts?
Is it in some way safer to set the Crack for a higher voltage than the socket provides i.e., safer to have the amp set for 240 volts with a socket providing 220 volts than an amp set for 220 volts with a socket providing 240 volts?
-Jørgen E. J.
Reply #3 on: February 15, 2018, 10:46:23 AM
Let's address that issue when you actually have it.
I have been at this a long time and helped quite a few overseas customers, and I haven't ever run into a 210V situation.
In my experience, you are likely going to need to move to a different country to get the kind of line voltage deviations that are currently concerning you.
Offline Kitchener
    • I made something!
Reply #4 on: February 15, 2018, 10:34:19 PM
So what you're saying is that I should definitely pack my Crack in the car and go on a cross-Scandinavia/Northern Europe tour so I can find an outlet that delivers either 220 or 240 Volts just so I can say "see? See!? Told you this would be a problem!"?  ;)
EDIT:
While we're on the subject of measurements; is a standard cheapo multimeter good enough for inspecting the Crack?
-the included image is of a $30-35 meter.
« Last Edit: February 15, 2018, 10:52:56 PM by Kitchener »
-Jørgen E. J.
Reply #5 on: February 16, 2018, 01:07:38 PM
Sure, that will certainly get the job done.
Offline Kitchener
    • I made something!
Reply #6 on: February 17, 2018, 09:11:11 AM
So I've measured the voltage at home and at the office.
Home: 240
Office: 230
So I need to choose wether to assemble the Crack for 225-235 Volts or 240 Volts and up.
Is this a big deal? What sort of problems can I run into if I use the wrong setting?
I want to use the Crack at home and at the office.
Mostly at the office, I think.
-I'll probably just bring it home over the holidays.
But I will naturally be assembling the Crack at home, with 240 Volts.
Sooo, what do I do?
-Jørgen E. J.
Reply #7 on: February 17, 2018, 11:09:48 AM
For perspective, remember that these power line voltages have always been variable. Most tubes are designed to work with voltages that deviate from the nominal by +/-10%. Wired for 240v, you can expect acceptable operation over the range 216v to 264v.
Offline Kitchener
    • I made something!
Reply #8 on: February 17, 2018, 11:21:02 AM
Okay, thanks that put me at ease.
All the options made me kind of nervous!
-Jørgen E. J.
