New Smash project
1026mind · 23287
Offline 1026mind
on: April 03, 2018, 08:43:11 AM
I am starting a new project, please feel free to post your feed back!
« Last Edit: September 25, 2018, 07:45:46 AM by 1026mind »
Offline faskenite
Reply #1 on: April 03, 2018, 10:00:09 AM
What are those tube sockets?  They don't look like they have solder lugs.  How do you solder pins like these?
Offline 1026mind
Reply #2 on: April 03, 2018, 11:27:41 AM
They are Yamamoto Teflon sockets, you solder them just like the turrets!
« Last Edit: April 17, 2018, 08:26:08 AM by 1026mind »
Reply #3 on: April 04, 2018, 04:18:17 AM
I've had nothing but problems with those teflon sockets, and have often had to remove them from builds that come in for repair.  They will be a bit easier to get out of the Smash at least.
Offline faskenite
Reply #4 on: April 04, 2018, 08:28:01 AM
What is the problem with teflon?  The material, the construction, or those pins?
Reply #5 on: April 04, 2018, 08:49:07 AM
In my experience, the pins end up getting flaky pretty quickly.
Offline Leland Hankins
Reply #6 on: April 04, 2018, 02:12:16 PM
Paul are you talking about the Yamamoto Teflon sockets (bronze/silver/100% gold), or the cheaper Chinese sockets, with bronze/nickel/gold(33-50%) .  I have never had or heard of a problem with any Yamamoto sockets.  I have used quite a few of their Teflon sockets.
Reply #7 on: April 04, 2018, 04:34:40 PM
My experiences were back before the Chinese sockets came around, or at least I hadn't figured out how to buy them yet.
I actually really like the Chinese 4 pin jumbo Teflon socket.
Offline 1026mind
Reply #8 on: April 23, 2018, 10:28:47 AM
checking voltage and i have very low reading on A4 and A8 and B4 and B8, also led don't ligtt up!
« Last Edit: April 23, 2018, 10:34:50 AM by 1026mind »
Reply #9 on: April 23, 2018, 11:39:22 AM
How about the rest of your voltages?
Offline 1026mind
Reply #10 on: April 23, 2018, 01:11:59 PM
solved, the two outside socket where mounted 180 degree off!
sounds amazing!
Offline BNAL
Reply #11 on: April 23, 2018, 05:44:08 PM
Any pictures of the finished preamp? I would really like to see the underside. Based on your initial pictures it is probably one of the cleanest builds I’ve seen.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline 1026mind
Reply #12 on: April 24, 2018, 04:29:15 AM
Thank you!
Offline StevePL
Reply #13 on: April 25, 2018, 06:42:45 AM
That is very tidy. Nice job.
Now I have an idea of what is possible when I build mine.
Crack Speedball, HD600, HD 25 300ohm.
Audirvana +, Schiit Modi Multibit, Smash-Smash Up Clarity MR, Rotel 956 bridged 2x Mono, Revel Performa F30.
Fiio X5ii, Quickie, Quicksand, Blumenstein Orca
Offline faskenite
Reply #14 on: April 25, 2018, 08:14:10 AM
I wouldn’t have been able to figure out how to solder those tube socket pins!
