Right channel hum and no signal
Sp33ls · 37875
Reply #15 on: May 06, 2018, 12:19:28 PM
I'd go ahead and replace it, but consider ordering some extras.  These don't fail on their own, so I'd be very, very carefully inspecting the little resistors on that 6AQ5 socket to be sure they are present and well soldered, as a missing one or one with a loose joint would allow for the voltage provided to the TL431 to go too high, and then the 431 would fail.
Offline Sp33ls
Reply #16 on: May 06, 2018, 12:32:12 PM
https://www.mouser.com/ProductDetail/926-LM431BCZ-NOPB
^ This one works just fine, right?
Yeah, that's interesting... I wonder what did it. I'll buy several just in case I have a troubleshooting session ahead of me  :o
Hopefully it'll be as simple as replacing it and being back in audio nirvana.
Very much appreciate all the help, PB. I'm traveling this week, but I'll report back next weekend on my findings with the new LM431s.
Reply #17 on: May 06, 2018, 05:54:16 PM
I believe we buy the ACZ version of the 431.
Offline Sp33ls
Reply #18 on: May 06, 2018, 06:15:02 PM
Yeah, I looked at the datasheet and didn't see a noticeable difference. Do you know what differences there might be?
Reply #19 on: May 07, 2018, 04:16:33 AM
I think there might be some slight noise differences.
Offline Sp33ls
Reply #20 on: May 07, 2018, 04:27:54 AM
Okay, I could see that. The only real difference I saw between the two was that the "initial accuracy" was 2% for ACZ and 1% for BCZ.
I sent Mouser an email to see if they could swap it to ACZ just to be certain there won't be any issues. I also picked up a few extra transistors and diodes just to have as backup.
Does the LM431 protect the capacitors from hitting their voltage limits?
Thanks again!
Reply #21 on: May 07, 2018, 04:55:23 AM
No, the LM431 regulates the high voltage to 150V.
Offline Sp33ls
Reply #22 on: May 11, 2018, 11:16:59 AM
So, I swapped out the LM431 and plugged everything (including all the tubes) back in to see.
Still having the issue. But, I've noticed something interesting.
When I first turn on the amp (cold start), the voltages actually appear to be closer to normal (150V & like 2.5V), but then after several seconds, they both just take a sudden dip. What could cause behavior like that... a capacitor?
Reply #23 on: May 11, 2018, 11:27:58 AM
Pull the 6AQ5s and look at your Kreg voltages again, as well as the "X" voltage.
Offline Sp33ls
Reply #24 on: May 11, 2018, 11:37:13 AM
With or without the white lead from the 6AQ5 plugged in to Kreg?
Reply #25 on: May 11, 2018, 11:47:13 AM
The white lead can be connected.
Offline Sp33ls
Reply #26 on: May 11, 2018, 12:31:22 PM
KregA: 0.4
KregB: 1.38
60 VDC & 1 VDC on A side.
214 & 2.18VDC on B side.
« Last Edit: May 11, 2018, 01:17:34 PM by Sp33ls »
Reply #27 on: May 11, 2018, 02:25:45 PM
How about OA on the high current board on the bad side?
Offline Sp33ls
Reply #28 on: May 11, 2018, 02:49:07 PM
It was around 50VDC... oscillating a bit upwards.
Reply #29 on: May 11, 2018, 03:09:29 PM
With the 6AQ5 pulled out? (And the 6080 should be pulled out, but 12AU7 in) This is a bit of a tough one to debug since you said the amp was previously working.  Low voltage on OA on the C4S board tends to point to a miswire or short downstream of that board.
