Sorry for being a moron. Is this the right part? Eros build
gregoryahunter · 2749
Offline gregoryahunter
I should probably know this - but I'd rather ask than have to remove something I soldered in because Im not very good at removing solder!
The picture in the assembly manual shows a white rectangular box as the "270W 5W wirewound resistor" (pic attached).  I dont have anything like that in my kit.  I have a green 270 Ohm 5W resistor (pic attached).
I assume that the "270W" in the manual is a misstype and the green 270 Ohm resistor that I have is the correct part?
Thanks in advance
Offline fullheadofnothing
Reply #1 on: August 20, 2018, 04:30:44 AM
Yes
Reply #2 on: August 21, 2018, 02:27:15 AM
THANKS!
Offline bsadowski
Reply #3 on: October 10, 2018, 02:57:46 PM
Thanks in advance
I also have noticed the same thing and asked the same question in an email to bottlehead wondering if the part was missing in my kit.  So if you are a moron...you're not the only one  :)
Reply #4 on: October 10, 2018, 06:57:23 PM
Yup, that's the correct substitute.
