Caps upgrade eros2
Alby0521 · 2626
Offline Alby0521
on: November 12, 2018, 05:04:49 PM
Hi
Got my Eros 2 on the way. Wondering what cap I should consider to replace the following:
- 0.1 if 400 V film capacitors
- 1.5 if 630 V capacitors
I heard V caps and Mundorf can be very good. Any experience with those and what model/series is recommended ?
Best
AB
Reply #1 on: November 13, 2018, 04:33:20 AM
There's a good amount of space for different caps in the 1.5uF/630V position.  You can nudge that value down to 1uF if the capacitor sizes are more reasonable, and a 400V rating is plenty.
The 0.1uF/400V caps mount to a PC board without a ton of extra space.  Consequently we provide a nice film and foil capacitor for this position with the kit.
Offline Alby0521
Reply #2 on: November 13, 2018, 07:53:50 AM
Hi Paul,
Thanks for the reply.
I can get at a reasonable price from somebody I know a pair of Mundorf silver/oil supreme 1000v.
Do you think that would be a nice upgrade or a waste for the capacitor being used in the Eros section?
Best
AB
Reply #3 on: November 13, 2018, 07:58:35 AM
When you buy a 1000V cap, it will be huge.  The same cap in a 400V size will be significantly smaller and weigh less.   Having said that, I think you'll be able to fit those into the kit, but please use an adhesive wire tie anchor and a zip tie to hold the weight of the caps so the leads don't break off.
Reply #4 on: November 13, 2018, 08:53:33 AM
I'll suggest screwing the adhesive wire tie anchor to whatever it is attached to. They usually have a hole in the center for that purpose. The heat in the amp can cause the adhesive to let go over time. I've picked up many an amp with dangling caps - not pretty.
