[Speedball] Big board voltage (RESOLVED)
manolito · 3798
Offline manolito
on: November 19, 2018, 02:05:47 PM
Hi,
I'm almost done assembling the speedball upgrade. Voltage on the small board were all good. Resistance on the big board were reading around 25MΩ or OL. I guess it's good since it's supposed to be very high.
Voltages on the big board are wrong however. G and B+ are good, but OA and OB read respectively 123V and 107V. All led are lit.
Any idea what could be wrong here ? I attached photos of my boards.
Thank you !
« Last Edit: November 24, 2018, 10:09:46 AM by manolito »
Reply #1 on: November 19, 2018, 03:23:10 PM
What are OA and OB on your small board looking like?
Reheating the joints on the big C4S board never hurts when it isn't working properly.
Offline manolito
Reply #2 on: November 19, 2018, 03:40:20 PM
Around 75V each (73V for OA, 76 for OB).
By C4S board, you mean the big one ? If so, I'll redo a quick pass on the joints tomorrow, to make sure everything is soldered properly.
Offline manolito
Reply #3 on: November 20, 2018, 11:28:06 AM
I've done a pass on joints on the big board. Still no luck  :-\
Reply #4 on: November 20, 2018, 01:46:45 PM
Could you post some updated photos of the build?
The 107V isn't a problem, but the 123V is a bit out of range.
Offline manolito
Reply #5 on: November 20, 2018, 02:13:40 PM
Sure, here you go ! Let me know if there's something in particular you'd like to see.
I should probably mention that I messed up with one 2N2222A transistor (the one near OA) and had to desolder it and reorder one on digikey. I got this one : https://www.digikey.com/product-detail/en/central-semiconductor-corp/2N2222A/2N2222ACS-ND/4806845
The desoldering part was not easy to me, and it's entirely possible that I did something wrong here.
Edit : added a photo of the underside. I can't do any better without either desoldering the wires or cutting them, Let me know if you need it !
« Last Edit: November 20, 2018, 02:21:13 PM by manolito »
Reply #6 on: November 20, 2018, 04:06:24 PM
These are still not soldered all the way.  You may need to hold the iron on these joints much, much longer, but one of them does look good.
Reply #7 on: November 20, 2018, 04:18:04 PM
Here's another one.
Offline manolito
Reply #8 on: November 21, 2018, 02:39:30 PM
Hello,
So I resoldered the joints you mentioned and I rechecked the other joints. Still no luck, I still get around 124V from OA and 104V from OB. I attached some updated photos.
Quick safety question while I'm at it. When resoldering the wires of the big board, I accidentally soldered the board backward... Of course, nothing worked, so I promptly unplugged the amplifier, waited for 1-2 minutes and tried desoldering the cables, and I took an electric shock, which left me a bit... shocked. (pun intended) The blue capacitors were still charged around 40-50V, going down really (really) slowly. I discharged them and resoldered the board the right way. Now it's back to how things were before (tube lit, LED lit, same voltage readings as before), so I assume I didn't fry the power supply at least. Can I safely assume that my mistake will have no further consequences ?
Thank you !
« Last Edit: November 21, 2018, 02:41:21 PM by manolito »
Reply #9 on: November 22, 2018, 07:43:18 AM
The 100uF caps discharge through the 2.49K resistors on the headphone jack, or through the solid ground connection on the headphone jack itself.  If these are not discharging, then there's an issue with the build that was present before you installed the Speedball.
There are still some solder joints where the solder isn't wicking all the way up through the hole.  It also looks like the wire going to B6 isn't soldered well at B6.
« Last Edit: November 22, 2018, 08:00:29 AM by Paul Birkeland »
Offline manolito
Reply #10 on: November 22, 2018, 10:31:36 AM
Strange. Is it possible that the amplifier was working despite this problem ? The amplifier passed all tests and it did work fine. I even used it for a whole week before I started working on the speedball.
Anyway, before anything else, I'll try fixing that issue with the capacitor not discharging, as it's making working on the amplifier downright dangerous. I'd rather not have it discharge to my heart. :P
Upon rechecking with the now properly setup board, only the capacitor on terminals 9-10 is not discharging. When I check for voltage, it's dangerously high (around 120V). Based on what you said, it's probably a bad solder on the way to the headphone jack/headphone jack ground, right ?
When I'm done with that, I'll redo those other solders.
Reply #11 on: November 22, 2018, 10:33:21 AM
Follow the wire leaving OA to the terminal strip, then to the tube socket.  I would bet the wire between the terminal strip and the tube socket isn't well soldered.
Offline manolito
Reply #12 on: November 22, 2018, 12:10:34 PM
I resoldered the capacitor. It was hard to bend the legs because they were inserted from the other side. Now it's much easier to bend them out of the way for the big PCB. I also went and added some solder to the joints on the way to the tube socket, to the headphone jack and the ground near the power socket. It's no use, the transistor is still fully charged when unplugging the amplifier. I attached some new photos I made after resoldering all that.
Reply #13 on: November 22, 2018, 01:51:06 PM
That's still looking cold.  You want to see the solder flow around the wire.  If it doesn't, the flux will float to the top of the solder and insulate the solder from the wire if the solder doesn't flow all the way around it.  More heat is the answer here.
Offline manolito
Reply #14 on: November 22, 2018, 02:53:53 PM
Hello again !
I resoldered the joint you mentioned. Should look much better now. I attached a photo.
That said, the capacitor is still charged when unplugging the amplifier. I figured I'd do some additional tests before coming back to you :
  • Black lead on 10, Red lead on B6 : 120V
  • Black lead on 10, Red lead on OA : 120V
  • Black lead on headphone jack, Red lead on 9 : 120V
Does that mean that electricity can travel between this points ? If so that would exclude a solder issue on those specific points.
