Speedball upgrade - small board: One LED not lighting, one V reading out of spec
Luxifer · 5109
Offline Luxifer
I am pretty sure I cut the leads to the resistors too close to the resistor body to re-use them. Unless there is some technique to re-attach wires that doesn't leave them brittle? I tried to solder them, but I was soldering between two flat faces, and the result was very brittle.
Are there any important specifications to the resistor, besides it being 22.1 kOhms? I can likely find one in the city I'm in, and test using that.
20K-24K is going to work fine.  I'd look for a resistor that's around 1/2-1W.
Offline Luxifer
Tested with some 22 kOhm resistors, and all was good, so I went ahead with the replacement part build, installed the rest of the Speedball, and everything is working perfectly.
Thanks so much for your help!
