Damaged Rubber
bombay317 · 12070
Offline bombay317
on: January 15, 2019, 09:04:09 PM
I have cats. They have claws. One of them damaged the speaker. Is it possible to repair this, or is this a replace? It’s on the rubber, is there a glue that works for this?
I have to convert the images I took to attach them.
Niagara 7000
Benchmark DAC3L (XBOX1 and TV)
CA Performance w/ Satisfy Turntable
Talismann V2 CA Cartridge
Tavish Designs Adagio Vacuum Tube Phono
BHSE Amp
Stax SR-009
BeePre 300B w/ BeeQuiet and Cinemag Transformers
Kaiju 300B w/ DC Filament
Jäger Speakers
Transparent and Benchmark Cables
Reply #1 on: January 16, 2019, 04:12:57 AM
Like the rubber around the woofer surrounds?  I would just replace the woofer, that's not the easiest place for glue to hold up.
Offline bombay317
Reply #2 on: January 16, 2019, 04:17:02 AM
Yes, that is it. its the rubber gasket at the end of the cone that attaches to the front metal ring. It is the part that is the flexible seal to keep air in and sound on the outside.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #3 on: January 16, 2019, 05:28:27 AM
It's called the surround. You could try some silicone sealer but as PB says it may not hold up. I would try it and if it doesn't work, get a replacement driver.
Reply #4 on: January 16, 2019, 06:01:16 AM
More specifically, black or red RTV available at your local auto parts store, not bathroom caulk.
Offline Jamier
Reply #5 on: January 16, 2019, 08:38:52 AM
Madisound might be able to repair that but it's possible that it might cost as much as a new driver once you pay for shipping both directions.
Jamie
James Robbins
Reply #6 on: January 16, 2019, 09:51:03 AM
If a DIY repair won't hold I'm pretty sure the most cost effective approach will be to replace the woofer. We can provide info for a replacement if that is deemed necessary.
Reply #7 on: January 16, 2019, 02:50:02 PM
If the damage is slight, I have used a dab of rubber cement to seal small tears
I have cats too.  8)...John
Offline Jay
Reply #8 on: January 17, 2019, 02:51:19 AM
Ouch.  I had a cat problem too, but not as bad.  The cat loved to stick his paw into the port and drag out the insulation.  I installed a metal grille to put a stop to it.  Parts express has some. https://www.parts-express.com/cat/steel-speaker-grills/323
The "cat" in the IRL is prophetic :)
Jay L.
Offline bombay317
Reply #9 on: January 28, 2019, 02:40:39 AM
I have converted the images and am uploading them of the before and after.  I used the black RTV.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Offline Sugar Man
    • The Last Honest Lawyer
Reply #10 on: February 09, 2019, 09:03:38 AM
I would have used the red RTV to cat shame the varmint.
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Offline bombay317
Reply #11 on: February 18, 2019, 09:19:43 PM
well it turns out that they did it again and more extensively this time.  Ill be trying to order a replacement speaker and will try the grills.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Offline bombay317
Reply #12 on: February 25, 2019, 11:34:23 PM
I wanted to add an image of the second repair of the damaged speaker.  It is a mess, but the rubber gasket maker material holds my cat's shame all together!
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #13 on: February 26, 2019, 04:43:41 AM
This is not a huge deal, but that looks like it is the upper woofer. The lower woofer has less of the upper frequency range to cover. If the lower woofer has escaped damage it might work a little better in the upper position.
Note that this is based on assumption and is purely speculation.
