New Personalized Kaiju
Alonzo · 5752
Offline Alonzo
on: May 14, 2019, 06:31:34 PM
Thank you PB for a great build.  It would've taken me a month of good days to get this done.  Got 5 (5.1 and 5.7 mv) for hum.  I will listen for awhile to see if the DC filaments are needed. Now realize I must retire some amps to the garage.  Well, it's time I simplified my setup.
Now for burn in and speaker selection and tube swapping...
Alonzo
Alonzo
Reply #1 on: May 14, 2019, 09:23:57 PM
I'm glad it made it safely! How did that expanding foam cradle work out?
I got pretty lucky with all those big caps, there's only about 1/16" of clearance left between the lowest hanging caps and the counter top.
Offline Alonzo
Reply #2 on: May 15, 2019, 04:17:16 AM
The expanding foam is a good idea, kept everything stable (along with the metric butt-ton of packing peanuts).  I see what you mean by the chicken head knobs, I replaced them with the larger set but they still sit too high, will change to black knurled knobs.
I got a pair of GE 5 star 5670's, should I check the driver voltage (175v) at each tube swap?
Alonzo
Reply #3 on: May 15, 2019, 04:36:14 AM
Pretty cool.
It looks like the plate chokes are mounted on standoffs - assuming this is the case, is this for ease of wire routing, or does it serve some other/additional purpose (e.g., additional distance from the OTs above)?
Derek
Reply #4 on: May 15, 2019, 05:02:53 AM
If the driver plate voltage is off by a few volts, it isn't going to be particularly audible.  If you plan to roll a lot of driver tubes, you could just set each cathode at about 4.2V and not worry about it till you have the pair you like.
The chokes are mounted on standoffs because the output transformers have been changed from our OT-5 to a pair of TFA-2004.  In order to keep each TFA-2004 centered on each 300B, the transformer leads needed to pass right through the space now occupied by the plate choke, so I spaced them up off the chassis.
Offline borism
Reply #5 on: May 17, 2019, 07:09:38 AM
What is the benefit of the TFA-2004 output transformer?
Boris
Reply #6 on: May 17, 2019, 08:25:55 AM
That particular pair is a one-off TFA-2004 with four different lamination materials and silver wire on the secondary.  It's a different flavor.
Reply #7 on: May 17, 2019, 09:18:25 AM
The Magnequest "Mexico"?
Offline Alonzo
Reply #8 on: May 17, 2019, 09:54:41 AM
Yep,
I was luckily going back and forth with Mike when these came out and ordered 2 of the three, I should've gotten them all.  The other pair is in a Stereomour II.
Alonzo
Reply #9 on: May 17, 2019, 12:39:32 PM
Sweet. The lamination pattern looks cool - imagine they sound very nice.  I really like the brass end bells - did you keep the brass look for the SII? I'd love to know where Mike gets those.
Reply #10 on: May 17, 2019, 01:26:17 PM
Mike paid a crap ton many, many years ago to have them custom made.
Offline Alonzo
Reply #11 on: May 17, 2019, 02:36:04 PM
The brass bells were painted for the Kaiju, the other pair is a basic black.
Alonzo
Offline Raymond P.
Reply #12 on: May 17, 2019, 05:53:05 PM
What's the reason for 3 binding posts per side?
Raymond P.
Offline Alonzo
Reply #13 on: May 17, 2019, 06:39:03 PM
Convenience, connection for 8 or 16 ohms.
Alonzo
