Voltage too high/LEDs not turning on
ganoosh · 2021
Offline ganoosh
on: June 13, 2019, 01:07:38 PM
This was my first time assembling an amp--got to the voltage check and had some high voltage readings for some of the terminals. Results below:
1. 145
2. 163
3. 0
4. 164
5. 148
6. 0
7. 146
8. 0
9. 147
10. 0
Also neither the LED attached to A3 or A8 lit up. I'm attaching photos.
What should I be troubleshooting here first?
Offline ganoosh
Reply #1 on: June 13, 2019, 01:08:45 PM
More photos just in case.
Reply #2 on: June 13, 2019, 01:16:40 PM
Did you pass the glow test?
Offline ganoosh
Reply #3 on: June 13, 2019, 01:22:32 PM
Yes, both were glowing and there was heat coming off them. Did a loose wire check and didn't see anything. Should I post more pictures?
Offline Jameson
  • Intern in Chief
Reply #4 on: June 13, 2019, 01:33:13 PM
Shouldn’t there be a black wire on the center pin of the front tube going to the pot?
Jameson O'Guinn
Managing Partner
Offline ganoosh
Reply #5 on: June 13, 2019, 04:32:07 PM
Ah, thank you so much Jameson! That was it, I had somehow totally omitted that during installation. Soldered that one in, voltage readings are correct and the thing sounds AMAZING!
