Stock Crack Loud Buzz/Hum Left Channel
Troycnc · 6781
Offline Troycnc
on: July 23, 2019, 02:55:04 PM
Hello,
Just built my first Crack and it went pretty well, directions were spot on. All readings are in spec per instructions.
When i first power it on it is dead quiet but within 10 to 15 seconds a hum/buzz starts to build until it is extremely loud and I have to power the unit off. It do'sent matter what the volume is set at.
Spoke with Dan and he recommended re flowing joints. I went back over everything and noticed 1 LED wasn't lit (A3) and Dan recommended  to remove the bad LED and Jump A8 to A3.
Still The Same Hum. Not sure what to do next. If anyone has any ideas I would greatly appreciate it.
Troy
Reply #1 on: July 24, 2019, 10:04:46 AM
If one LED wasn't lit, then your voltages were not consistent with what's in the manual.
I would cut the jumper out and measure the voltages on terminals 1-5, then post them here.  At least one of them will not be correct.
Offline Troycnc
Reply #2 on: July 26, 2019, 01:26:53 AM
Hello Paul,
Thanks for the help. I have removed the jumper I installed from A3 To A8. The voltages are below measured from chassis to terminals 1-5.
1-.209
2-.639
3-0
4-.639
5-40.91
I really appreciate any advice you can give, really looking forward to hearing it run.
Troy
Offline Troycnc
Reply #3 on: July 26, 2019, 02:02:11 AM
Sorry Paul,
Checked them again from 12U to 1-5.
Voltages are out of spec for sure.
1-.135
2-.630
3-0
4-.631
5-40.63
Once again i really appreciate your help
Reply #4 on: July 26, 2019, 10:28:57 AM
So you are saying you have 0.63V on terminal 4 and 40V on terminal 5?
This can only happen if the string of black wires going across the 6 lug terminal strips, then up to the headphone jack, then over to terminal 3, then to the volume pot and back to the 9 pin socket has a really poor connection or one wire completely missing.
It might help also to post images of your build.
When you mentioned previously that your amp passed all the checks, does that mean you got appropriate voltages at some point?
Offline Troycnc
Reply #5 on: July 26, 2019, 11:18:40 AM
Hey Paul,
I apologize for not explaining it better. I got proper readings from the transformer at the begining of build but never had proper readings from the terminals. I have gone over the wiring again this afternoon and it looks right to me? I have attached a picture if that helps.
Troy
Offline Troycnc
Reply #6 on: July 26, 2019, 11:28:15 AM
Paul,
I also removed the jumper and LED this afternoon, waiting on a replacement.
Reply #7 on: July 26, 2019, 06:13:49 PM
Why did you remove the LED?  The voltages you have are not at all indicative of a bad LED.
Offline Troycnc
Reply #8 on: July 27, 2019, 01:31:37 AM
It wouldn't light anymore
Offline Troycnc
Reply #9 on: July 27, 2019, 01:45:02 AM
Would it not light because of the voltages? What do you reccomend I do waiting for replacement. I was thinking of rewiring the ground path. I'm not sure what to test for to see if that's the problem or if it is a component.
Offline Deluk
Reply #10 on: July 27, 2019, 02:42:46 AM
The picture shows neither of the led's fitted. Are you replacing both?
Reply #11 on: July 27, 2019, 11:58:04 AM
Yes, your voltages were all out of whack and did not at all indicated a bad LED whatsoever.
I would strongly suggest doing absolutely nothing until the replacement LEDs arrive.
What do you mean by "rewiring the ground path"?  Are you intending to pull out all the black wires and replace them? (please don't).
The problem is not a component.  The problem is almost certainly a bad solder joint or a missing connection that is causing these issues.  I suggested this in a post earlier.
I've also posted an image from the voltage checks in the manual regarding what a dark LED might indicate...
« Last Edit: July 27, 2019, 12:04:19 PM by Paul Birkeland »
Offline Troycnc
Reply #12 on: July 28, 2019, 01:54:13 AM
Thanks for taking time to help Paul. I can tell your irritated I'll get it figured out.
Troy
Reply #13 on: July 28, 2019, 04:10:18 AM
Hey Troy - I'm certain PB will help you get it sorted out - he designed the circuit so no one knows it better. I really recommend continued use of the forum for troubleshooting. The Crack is a fairly simple circuit, so causes of the problem are limited and almost certainly will be found.
I think Deluk's question above is still relevant: your build pic shows two LEDs missing - did you remove them both?  If so, did you keep them? If the leads are still long enough you could try re-installing them and then progress with the troubleshooting.  The first step of which would be to redo the resistance checks, and if that checks out ok, to redo the voltage checks. Post any deviations from the values specified in the manual.
And if it's any consolation: I've spent 20+ hours this past week trying to get a mod to my Beepre to work and am still not there yet - but PB has been helping me and I will eventually get the problem solved. Against my instincts, I've come to accept that the best way of dealing with a problem amp is to take a methodical approach: check one possible cause, and if that's not it, move on to the next, and so on until it's fixed. It takes time, but it gets the problem solved and avoids creating new ones (I've created a lot of "new ones" in the past by fiddling with things that didn't need fiddling with). PB knows the possible causes of the problem and can guide you through the steps to identify which one you're dealing with and how to fix it.
cheers, Derek
Reply #14 on: July 28, 2019, 05:16:35 AM
I'm still here and happy to help, but it is really helpful to not try to get too far ahead of things, otherwise the process can grind to a halt.  This is super duper common when an LED isn't lit up, and we often get tech help posts that simply provide the information that one of the LEDs isn't lighting, with no additional information.  This is why we put that information in the manual, as there is only one condition that would indicate a damaged LED, and the information you provided did not indicate that.
Until you can put LEDs back in your Crack and power it up to take some additional measurements, it will be tough to do any other debugging, as the amp can't be powered on in its current state to check for progress.
One thing I would absolutely recommend doing would be to take your meter and try to read the DC voltage across a 9V battery, just to be sure that the meter is working properly.
