120V to 220V higher readings, 2nd problem noticeable hum both channels
Jimb0 · 5192
Online Paul Birkeland
One of the tubes won't make both channels hum.  You could also double check the resistance checks to see if anything looks odd there. You could also get hum if a power supply cap became disconnected, but in order for that to happen in both channels, you would also see improper B+ voltage.
