Seduction problem
wesleyHK · 17594
Offline wesleyHK
on: August 15, 2019, 08:19:26 AM
Hi,
I haven't been on this forum for over 10 yrs.  I've got problem, I assume this is the correct place to ask about my problem?
I have a Seduction with C4S upgrade that I built over 10 yrs. ago.  It's been stored for many years, but I started using it last week with no problems.
Yesterday I was using it and the all of the sudden I get a lot dadadada sound, loud enough to have to turn it off.
I looked under the unit.
The LED's at tube pin 3 and 6 are flashing.  So are two on the C4S board.
I switched out the tubes for another pair, but still same problem.
I don't think I have the manual anymore, since I moved back to the states 3 yrs. ago.
I have no idea how to troubleshoot it.
I hope someone can help.
Regards,
Wesley
Reply #1 on: August 15, 2019, 09:37:10 AM
Hello Wesley,
Yes, this is certainly the place to post.
What you are describing would likely come from a loose connection or unsoldered joint somewhere in the Seduction.  You could power up the Seduction with nothing attached at the inputs and outputs, then carefully poke around with a wooden chopstick to see if you can find a spot that changes the behavior of the preamp.  That will help narrow down your resoldering efforts.
Offline wesleyHK
Reply #2 on: August 15, 2019, 09:46:08 AM
ok, thanks Paul.
Offline wesleyHK
Reply #3 on: August 15, 2019, 07:01:32 PM
Hi Paul,
I fixed it.  It was a switch I put in many years ago to allow for setting the input loading.  I had it in the center position, it should have been in one of the two other positions.  Stupid me forgot after all these years.
I have 2 phono amps and a pre-amp I built over 10 years ago and they are still going strong.  I've never had any problems whatsoever.  Your gear is the best.
Thanks again for your help.
Wesley
Reply #4 on: August 16, 2019, 04:42:46 AM
It sounds like it's time for a switch with no center position!
