Bottlehead Kits
Legacy Kit Products
Crack-a-two-a
1 LED lights up immediately after turning it on, smoke from one of the 270ohm 5w
Jimb0
15970
Paul Birkeland
Global Moderator
Hero Member
Re: 1 LED lights up immediately after turning it on, smoke from one of the 270ohm 5w
Reply #15 on:
August 27, 2019, 02:18:20 PM
Now remove the wire leaving OA (that goes to the terminal strip) and recheck.
Jimb0
Sr. Member
Reply #16 on:
August 27, 2019, 04:18:16 PM
still nothing PB
Paul Birkeland
Global Moderator
Hero Member
Reply #17 on:
August 27, 2019, 06:17:08 PM
Can you post photos of the board?
Jimb0
Sr. Member
Reply #18 on:
August 27, 2019, 06:20:55 PM
Sure PB, will post them in a bit
Jimb0
Sr. Member
Reply #19 on:
August 27, 2019, 06:32:55 PM
pics
Jimb0
Sr. Member
Reply #20 on:
August 27, 2019, 06:35:53 PM
btw, one of the rings on the board for the 2n2222 came off on the bottom side but i was able to solder the top side
Also, none of the LED's light up on that board. I remember all of them use to light up when I tested it the first time around before the 270 ohm starting smoking
Last Edit: August 27, 2019, 06:38:27 PM by Jimb0
Guest
Reply #21 on:
August 28, 2019, 03:27:33 AM
Jimb0 - Don't know if this will help, but it's worth a shot. From your first pic of the board underside it looks like there are lots of little solder shards around the soldered legs of the transistors - they might be forming a solder bridge and shorting the legs together. Maybe try gently scraping them off.
cheers, Derek
kgoss
Sr. Member
Reply #22 on:
August 28, 2019, 04:27:30 AM
Check the LED orientation.
Maybe I'm wrong, but from the pictures it appears the LEDs on the B side are in backward according to the silkscreen on the board.
Last Edit: August 29, 2019, 02:51:54 AM by kgoss
Ken Goss
Paul Birkeland
Global Moderator
Hero Member
Reply #23 on:
August 28, 2019, 04:35:34 AM
I would recommend contacting replacement parts and asking for a new board, transistors, resistors, and heatsinks/mounting kits. Once the traces start to lift off, getting the board to work can be more challenging.
Jimb0
Sr. Member
Reply #24 on:
August 29, 2019, 12:05:25 PM
Will do, thanks PB
Bottlehead Kits
Legacy Kit Products
Crack-a-two-a
