Something new - 2A3 monoblocks
Doc B. · 7502
on: November 01, 2019, 06:13:46 PM
PB, PJ and I have been working on a new project for the past couple months. This is our new premium 2A3 monoblock amplifier. It is designed to run a broad range of 2A3 variants up to and including the JJ 2A3-40 by virtue of a two way switchable operating point. The current draw of the 2A3 in a given operating mode is indicated by the meter. It uses a parallel feed output stage and a cap coupled, shunt regulated driver stage. It uses the big OT-5 output transformer that we use in the Kaiju. I'm going to let PB weigh in on the performance specs of various 2A3 tube types, as he is the one who has been playing with them. Sonically it is a little more towards neutral than a Kaiju (a but less lower midrange/upper bass weight) and thus has a little bit more resolved sounding vocals and a wee bit more top end shimmer. That said, with similar circuits and iron both amps are definitely from the same sonic family. Universal power transformer, and a very low noise floor similar to the old Paramount monoblocks. Kit price is estimated at $2250 for the pair of monoblocks. Yes, those shrouds and the black finish are how the production kit will look.
« Last Edit: November 01, 2019, 06:28:38 PM by Doc B. »
Reply #1 on: November 01, 2019, 06:16:17 PM
If the image is way too big when you open it, right click on the image and click "open in new tab". Then open that tab.
« Last Edit: November 01, 2019, 06:30:17 PM by Doc B. »
Offline Jameson
  • Intern in Chief
Reply #2 on: November 01, 2019, 07:09:03 PM
That’s really exciting! Congrats, guys. I’d love to grab a pair someday - but I probably ought to finish the Kaiju and the Bee Pre first. And get better speakers. And a better turntable. And a good bankruptcy attorney.
Jameson O'Guinn
Managing Partner
Offline Bonzo
  • My name is Marco, best known as Bonzo
Reply #3 on: November 01, 2019, 08:23:31 PM
REALLY nice!
And really apartment-friendly!
These would be my dream now
Bisogna avere orecchio!
Offline triode
Reply #4 on: November 01, 2019, 10:17:02 PM
Very intriguing...
More info please : what is the driver tube? how much power with JJ2A3-40? DC filament option? looks like 8X10 base size like Paramount?
Reply #5 on: November 02, 2019, 06:13:38 AM
The driver tube is the 5670.
7W @ 10% THD with the switch on the higher current operating point.  The Sovtek 2A3 that we will send with the kit will make 6.5W or 5W depending on the switch position.  I suspect the big EML 2A3 will also be around 6-7W, but we don't have a pair on hand to try out.  The fun thing about this amp is that you can go from the low current operating point with an RCA 2A3 to the high current operating point with the JJ 2A3-40 and go from listening to a 2A3 to 300B amp very easily.
The amp will come with DC filaments straight away.  The chassis is 10"x12".  The larger chassis helps fit the substantially larger iron, and it helps keep the amp running a bit cooler on the inside.  We are also providing the amp with film cathode bypass caps, and that requires a bit of extra space as well.
Offline kgoss
Reply #6 on: November 02, 2019, 07:26:16 AM
Great looking amps guys. And since you designed them I know they will sound as good as they look. They will definitely go on my wish list. I don’t really need them, but I want them! 😃
I’ll go ahead and ask if these can be modified to run 45 tubes, since its a standard forum question for a 2A3 amp.
Ken Goss
Reply #7 on: November 02, 2019, 07:34:36 AM
Yes, you'd have to change 3 resistors to make it into a #45 amp.
Offline Raymond P.
Reply #8 on: November 02, 2019, 07:49:02 AM
What are you guys going to name this kit?
Raymond P.
Reply #9 on: November 02, 2019, 07:52:29 AM
We may be open to suggestions on naming.
Offline Jameson
  • Intern in Chief
Reply #10 on: November 02, 2019, 09:07:34 AM
Since there are two and it’s based on the Kaiju: Bi-ju or Kai-two. Or something better.
Jameson O'Guinn
Managing Partner
Reply #11 on: November 02, 2019, 09:43:46 AM
Very cool. More questions:
(1) Choke? The Kaiju OT is mentioned, but not the plate choke. Is is it the Kaiju PC?
(2) OT impedance - wired for 3K, 6K, or some other primary impedance?
(3) Switching operating points - when switching between high and low current, does the amp also switch between choke inductances?
cheers and thanks, Derek
Offline kgoss
Reply #12 on: November 02, 2019, 10:30:35 AM
Name suggestion.
If the circuit is a refinement of the Paramour, Stereomour amps how about MonoAmore ...
Ken Goss
Offline Raymond P.
Reply #13 on: November 02, 2019, 10:52:04 AM
I was thinking along the same lines. Specifically, Monomour, a play on words on the French words "Mon Amour".
« Last Edit: November 02, 2019, 10:55:36 AM by Raymond P. »
Raymond P.
Reply #14 on: November 02, 2019, 11:24:32 AM
Yes, but with the full winding, so a bit more inductance.
The Kaiju OT is 3K.  I wouldn't be surprised if the performance wan't optimal trying to reflect 6K.
No, these don't run as much HV current as a Kaiju does, so there's no need to go to the lower current tap on the plate choke.
