Crack finish. Volts problems.
michael30 · 6155
Reply #30 on: November 22, 2019, 08:15:42 AM
I forwarded your e-mail to the replacement parts address to get you another download.
When in doubt about solder joints, just reheat them all.  This is what I do for any kit repair that I get in.  Reflowing all the joints in a Crack takes me 10-20 minutes at most.
Offline michael30
Reply #31 on: November 22, 2019, 08:41:46 AM
I will do it , thank Paul. I have to admit again I've never encountered customer service like yours, maybe it's because of the country I live in, yet, I have to put it to your credit. Thanks and appreciation.
 Michael
Offline michael30
Reply #32 on: November 22, 2019, 09:11:41 AM
I check my voltages before 2 and 5 is 191v and 7 is 115v.
I rechecked my apartment outlets and it 240.1.
When I solder the power I did it for up to 235.
Do I need to change it? May it damage the amp?
The real problem is that I sometimes use outlets that give out about 228-235
And in my other apartment it’s 240.1 .
What do you think I should do?
Reply #33 on: November 22, 2019, 09:52:18 AM
The manual says 170V +/-10%, so there's no issue there.
7 is 115v.
The manual says 7 can be 90-115V.
No.
Nothing... listen to the amp instead of worrying about it.
Offline michael30
Reply #34 on: November 24, 2019, 12:34:36 PM
After speedball, I’m satisfied, all working well with my cbs jhy 5814A.
The only thing that disappoints me is the stock 12au7 that making so much static and chucking,
I do not know the reason to it... barely used it, and can’t be use now because all of the unbearable noise. At least the cbs I dead quiet.
Reply #35 on: November 24, 2019, 02:00:50 PM
Try letting that tube run for 50-100 hours, often times some run in time will resolve issues like that.
