Lost left channel
hibuckhobby · 1707
Offline hibuckhobby
on: November 12, 2019, 05:06:28 AM
After several weeks of working well, the left channel began to delay in coming on, but after
a minute or so, it would come in with a slight pop and work perfectly.  As of today, it only
passes a very low level signal.  I've gone over all of the left channel connects and reflowed
the solder joints.  Occasionally the left side will come in, but distorted.  Where should I start
looking?
TIA,
Bob
Reply #1 on: November 12, 2019, 05:11:03 AM
I would start with a voltage check.
Offline hibuckhobby
Reply #2 on: November 12, 2019, 05:27:39 AM
Voltages as well as resistances all within ranges specified in manual.
ex:  1. 82v 2. 173v etc.  I changed the 12AU7 in case of a bad
driver, but that made no difference.
Bob
Reply #3 on: November 12, 2019, 05:36:14 AM
Can you post some photos of the build?  A channel that pops and drops will absolutely show a voltage problem, as pops come from important connections being intermittent.  Sometimes it's tough to get those connections to act up and to be able to get voltage measurements while that's happening.
Offline hibuckhobby
Reply #4 on: November 12, 2019, 06:26:20 AM
Hopefully these will be better than my last efforts.
« Last Edit: November 12, 2019, 06:29:17 AM by hibuckhobby »
Reply #5 on: November 12, 2019, 06:30:02 AM
The 9 pin and 8 pin tube socket wiring will have the connections that could could cause a channel to drop and pop, as could potentially the headphone jack.  The power supply that's built above the power transformer is common to both channels, so an issue there would cause both channels to drop.
Offline hibuckhobby
Reply #6 on: November 12, 2019, 08:25:42 AM
Thank you Paul.  I will investigate those sockets further when it cools down.
I left it one for a couple of hours and the channel came back on.  I suspect
that once I have redone all the joints on those tube sockets, the problem
will be corrected.
Bob
Offline Deluk
Reply #7 on: November 13, 2019, 04:05:45 AM
On bh1 has the green wire broken off?
