kill_surf_city · 11966
Terminals 2 and 4 are wired together with a jumper wire. I would guess that yours is missing or not well soldered.
Edit: google search came up with my headphone jack being miswired. Fixed it but now my voltages are all too low.
What was miswired? What did you change?"Too low" is not a number and doesn't tell me much about what's going on. Please post build photos at your earliest convenience.
Not sure if this is related to the problems you're having, but you have some leads that need trimming, particularly the one circled in the attached. It looks like it might be creating a short to chassis ground.cheers, Derek
A blue cap that gets hot could be in backwards, but I can't see that from your photos.
From the photo it looks like the top of the cap is already bulging. PB can tell you if it's still usable.
You really ought not try to listen to the amp with the voltages out of spec. Mouser will carry those capacitors, as will digikey
