Help with voltage [resolved]
kill_surf_city · 11953
Offline kill_surf_city
Reply #30 on: December 30, 2019, 12:10:45 PM
The LED should not turn on when you power up the amp.
Does this also happen with no tubes in the amp at all?
Can you post a fresh photo of just the 9 pin socket wiring?
When I take the tubes out the LED doesn't turn on at all. Here’s pics of the sockets as well. I’m about to take out the bad capacitor.
« Last Edit: December 30, 2019, 12:12:55 PM by kill_surf_city »
Reply #31 on: December 30, 2019, 12:42:13 PM
On the 9 pin socket, it looks like maybe the end of the LED going to A8 is touching the wire at A7.
On the 8 pin socket, it looks like some of the ends of the green wires need to be trimmed that are sticking out.
Do both halves of the 12AU7 still glow when the amp is running?
Reply #32 on: December 30, 2019, 12:57:53 PM
I’ll get to trimming! Also, yes both halves the the 12AU7 still glow. I have removed the bad cap.
Reply #33 on: December 30, 2019, 12:59:12 PM
Can you also carefully measure the voltages at A3 and A8?
Reply #34 on: December 30, 2019, 01:09:25 PM
A3 - 02.7
A8 - 01.9
Reply #35 on: December 30, 2019, 01:16:16 PM
Also after doing the trimming I’ve gotten terminal 9 to come down to 115-116 and terminal 5 down to 92.1
« Last Edit: December 30, 2019, 02:30:53 PM by kill_surf_city »
Reply #36 on: December 30, 2019, 04:44:08 PM
A3 - 02.7
A8 - 01.9
And they aren't glowing?!
I suspect that you have many cold solder joints.  If I had this amp on the bench for repair, I would reheat each one and let the solder flow out again.
Reply #37 on: December 30, 2019, 05:29:27 PM
The tube is glowing on both sides yes. But neither LED is lighting up. So are you saying i should re-solder the joints where the LEDs are connected?
Reply #38 on: December 30, 2019, 05:48:50 PM
Ok I resoldered the joint on the LEDs and got A8 to light up but broke A3 in the process. Something tells me that the A3 LED wasn’t in there very well to begin with. So I’ll have to order a new LED for that joint unless there’s some kind of work around for that. Thanks Paul!
Reply #39 on: December 30, 2019, 06:54:11 PM
You can install a wire jumper between A3 and A8.
I would resolder all of the joints in the amp, not just the ones where the LEDs connect.
Reply #40 on: December 31, 2019, 02:19:56 AM
Okay. How long should the jumper be? I’ll install that later tonight and then do a recheck of the voltages and post them here.
Reply #41 on: December 31, 2019, 09:47:34 AM
Long enough to reach between A3 and A8 and not touch anything else.
Reply #42 on: January 02, 2020, 01:44:37 PM
Okay, put the jumper cable in, the remaining LED is strongly lit, and I put in the replacement cap. The one I got is 160v 100uf but it’s a bit smaller looking. Either way, here’s my voltages. Should I be safe to try it out? 2,4,7, and 9 are on the high end but within 10% of the goal.
1. 94.8
2. 176.1
3. 0
4. 176.3
5. 93.6
6. 0
7. 115.0
8. 0
9.  117.1
10. 0
Reply #43 on: January 02, 2020, 02:00:31 PM
Those are functional voltages.
Reply #44 on: January 02, 2020, 02:11:36 PM
Works and sounds incredible! Thanks a lot for you help Paul and everyone else here!! Im sure I’ll be back when the times comes to install the Speedball
