Noisy Tube
gbcook2 · 1408
Offline gbcook2
on: December 27, 2019, 11:05:44 AM
Hi - the large tube on my crack has been pretty noisy ever since i setup the kit.  Does anyone know where to buy a new one?  The tube starts to buzz and hiss and gets worse until I flick it or move it.   Thanks in advance.
Reply #1 on: December 27, 2019, 03:10:17 PM
I would be extra certain that the solder joints on the socket are solid, as thwacking the tube will jostle these joints.
6080s are very common, most tube dealers will have them.
Offline gbcook2
Reply #2 on: January 12, 2020, 11:28:39 AM
Thanks for the reply.  I went back through and reheated the joints.  I also noticed that the leads on the socket move around a bit so I tried to bend them a little to make them more solid.  The noise got quieter so I think it helped.   However, now at low volumes the left channel doesn't play music.  It will kick in at a certain point though.  Any ideas?  Thanks again.
Reply #3 on: January 12, 2020, 12:09:50 PM
How long does it take to kick in relative to the right channel?
Offline gbcook2
Reply #4 on: January 12, 2020, 01:02:47 PM
If 3:30 is no volume whatsoever, I can hear right channel at 4:00 but no left channel at all.  The left channel starts to kick in about 4:30-4:45.
« Last Edit: January 12, 2020, 01:41:32 PM by gbcook2 »
Reply #5 on: January 12, 2020, 01:50:41 PM
I don't know what those numbers mean.  Pots have about 270 degrees of rotation, is this happening in the bottom 1/4 of the rotation?  If so Crack FAQ #3 and #4 cover a simple mod for this:
https://forum.bottlehead.com/index.php?topic=4295.0
Offline gbcook2
Reply #6 on: January 13, 2020, 02:16:39 AM
Exactly, I was referring to a clock for my numbers.  It occurs at the bottom 1/4.  Thanks for the tip/link, I guess I will give it a try.  Just wondering why it the crack didn't have a volume imbalance before though?  All I did was reheat some joints at the socket and try and make them more solid.
