2N2222A Transistor and Standoffs
Mesz77 · 1053
Offline Mesz77
on: January 13, 2020, 11:37:37 AM
Hello all,
Ive run into a bit of a hiccup while adding speedball and a choke to my crack. I completely assembled the speedball boards, but I'm missing one 2N2222A transistor. I'm not sure if I was shipped only one, but knowing myself I most likely lost it. Are there any specifications that I should look for to replace it? Or would any 2N2222A transistor work as a replacement?
Now for the choke, I have yet to buy standoffs for it. Do I need to get nylon standoffs, or would it be okay to get brass or aluminum ones?
Brandon Meszar
PSU
Reply #1 on: January 13, 2020, 12:20:31 PM
Any old 2N2222 will work just fine.  If you have a local electronics shop, an NTE123A is the equivalent part.
For the choke, metal standoffs will be stronger.
