No sound in either channel (resolved)
Jimb0 · 5532
Offline Jimb0
Reply #15 on: January 27, 2020, 10:53:29 AM
just to be sure the 3K resistors are the ones that came with the non-speedball kit?
Reply #16 on: January 27, 2020, 10:54:32 AM
Yes.
Offline Jimb0
Reply #17 on: February 03, 2020, 01:31:29 PM
Just wanted to make sure I did this right
https://imgur.com/a/Kb6eKIB
also what voltages should I be checking here?
« Last Edit: February 03, 2020, 02:20:45 PM by Jimb0 »
Reply #18 on: February 03, 2020, 02:28:14 PM
7 and 9.
Offline Jimb0
Reply #19 on: February 03, 2020, 02:32:50 PM
219v at 9
6v at 7
Reply #20 on: February 03, 2020, 03:48:02 PM
For all of the connections on the octal socket, I would pull a little more wire through them and wrap it around the socket.
The 219V at terminal 9 makes me wonder if one of the black wires in the amp is loose.
If you happen to have a spare 6080/6AS7G sitting around, it wouldn't hurt to give that a shot as well, but having both 7 and 9 so far off in different directions would tend not to suggest a bad tube.
Offline Jimb0
Reply #21 on: February 04, 2020, 05:55:34 AM
Good morning PB. I rechecked the black wires and couldn't find anything that was loose, but I resoldered them just in case. I don't have a spare 6080 at the moment so I can't test it. However, my 6080 tube is a bit loose at the base (the metal part at the bottom), if that means anything. Rechecked the voltages and got the same readings at 7 and 9.
On another note, I actually remember hearing a noise the first time I turned the amp on a week ago. I'm not sure where the noise was coming from but it stopped working shortly after that. I had a spare 6080 tube (but later sold an amp with the tube) and tested that but by that time the big board stopped working. Do you think maybe the 6080 tube was the one making noise and is it possible that it messed up the big board?
I will buy a spare 6080 for testing.
Reply #22 on: February 04, 2020, 06:11:03 AM
Is one 3K resistor getting much hotter than the other?  You can run the amp for about 60 seconds, then shut it down and wait about 20 seconds, then safely touch the resistors.
The disparity in the voltages would make me wonder if both resistors would be cold.
Offline Jimb0
Reply #23 on: February 04, 2020, 06:21:16 AM
yes both 3k resistors are cold
Reply #24 on: February 04, 2020, 09:36:19 AM
So 219V DC across a 3K resistor will dissipate 16W.  That won't be enough to completely blow the resistor immediately, but it will get very hot in a hurry.  Since it isn't getting hot, this is almost certainly an issue of loose connections in the amp not properly conducting and giving anomalous readings.
Offline Jimb0
Reply #25 on: February 05, 2020, 07:04:39 AM
PB, I just resoldered every joint in the amp and paid close attention to the connections in the octal socket but I'm still getting the same readings.
Reply #26 on: February 05, 2020, 08:16:26 AM
What DC resistance do you get between terminal 12 and terminals 7 and 9?
Offline AB2KH
Reply #27 on: February 05, 2020, 08:53:06 AM
Hello JimbO and Paul. Paul correct me if I am wrong. In the above photo it appears that the 10K cathode resistor on the left side is connected to B+ which is flowing through it to the output cap which is shorting to ground through the head phone jack?? That resistor should be connected to the same ground point that the resistor on the right is connected to?? Don't plug your phones in!
Chris/AB2KH
Reply #28 on: February 05, 2020, 08:55:17 AM
Good eyes Chris, I didn't even notice that!
Offline AB2KH
Reply #29 on: February 05, 2020, 09:09:12 AM
Sorry, I meant 3K @ 10 watt resistor. Just to clarify,don't want confuse the confusion.
