Sound faded away from one channel / High voltage readings on Crack [resolved]
kattjaevel · 3665
Offline kattjaevel
Hi! When I first completed my Crack resistances and voltages checked out when measured, but after a while the sound in the right channel faded out.
Now when I measure the voltages I get some weird values. Between 12 and below points it's higher than expected. The A8 LED doesn't light up, nor does the topmost side of the 12AU7 glow
A6 145V,
B1 145V,
B3 145V
Any clues where to start figuring this out?
« Last Edit: March 12, 2020, 03:55:07 PM by Paul Birkeland »
Do both halves of the 12AU7 glow?  Can you very carefully measure the DC voltages at A3 and A8?
Often times an issue like this is the solder joint at A4/A5.  If it's not well connected, half of the 12AU7 will be extinguished and you will get all of these symptoms.
Offline kattjaevel
No, the filament attached to A8 doesn't glow.
I went over and redid the solder points at A4 and A5... They looked OK before but perhaps a bit better now. A4 doesn't have the best physical contact. However, they measured 0 Ohm impedance to ground before and after.
A3 measures 1.6V, A8 measure -1.0V DC...
Edit: I switched to the original 6080 (Apparently I had used another I had laying around) and with it, one of the sides does not glow as much as the other.
« Last Edit: February 17, 2020, 09:07:41 AM by kattjaevel »
Offline kattjaevel
some images:
(https://i.imgur.com/u3oGAeR.jpg)
(https://i.imgur.com/FxSfPo2.jpg?1)
(https://i.imgur.com/WbAKOKy.jpg)
1.  Power transformer terminal 9 has a wire going through it that almost touches power transformer terminal 10.  If those should ever touch, you will blow fuses endlessly until you trim that.
2.  Are both black wires captured by solder where they meet on the headphone jack?
3.  Is the wire that connects to A4/A5 passing through A4?  It looks like perhaps not?
Offline kattjaevel
Thanks Paul for the feedback!
I trimmed the cable at 9, was about 3mm of gap but it wouldn't be nice blowing a fuse during all of this. Resoldered the black wires at the headphone jack (they looked OK before). The wire goes through A5 and bends up at A4 so it locks in place. I had some more time today so will attach some more pictures that might be helpful. Starting the project a few years back I was using a really poor soldering iron (very big tip and wasn't heating properly at the tip) and had matching skills. So lots of joints look dirty. Is that something that could cause issues and I need to redo?
(https://i.imgur.com/YcfS5gY.jpg)
(https://i.imgur.com/fHG84QM.jpg)
(https://i.imgur.com/BMR3KAe.jpg)
(https://i.imgur.com/x1EdQVO.jpg)
(https://i.imgur.com/wtvmAm5.jpg)
(https://i.imgur.com/fZn4XFZ.jpg)
(https://i.imgur.com/TUd9Pyn.jpg)
Offline adydula
Remember if your iron isnt heating properly, you need to keep the tip clean before using, by rubbing on a wet sponge and using some flux....if you dont keep it clean you
will not get good heat at the tip needed for proper soldering.
Also sometimes the tip can become loose and needs to be tightened in the heating element....
I mention this because you stated having issues with heating and the tip...
Alex
Offline kattjaevel
Yes, I have gotten a new iron since and went over most but not all joints, some are quite hard to reach  ;D ;D
You can try a small wire jumper between A3 and A8.
Offline kattjaevel
Reply #10 on: February 21, 2020, 06:26:40 AM
I bridged A3 and A8 and still no action with the A8 connected filament. Is my tube bad?
Reply #11 on: February 21, 2020, 06:52:08 AM
So no change in voltage at terminals 1 and 5?
Is my tube bad?
There's about a 1/1,000 chance that your tube is bad.  There's a 999/1,000 chance that there's a bad solder joint, broken wire, etc. in the amp causing this problem.  This is based on your information that one channel just kind of faded off on its own.  If maybe the 12AU7 was dropped or something was dropped on the amp, then the channel dropped, that would be different.  When a tube goes from good testing to bad testing, it doesn't just turn off immediately.  There will be a period of a few thousand hours where things just don't sound right before things get so ugly sounding that you go looking for what's wrong.
Can you tell me if both halves of the 12AU7 glow?  I asked before and I think you thought I was referring to the LEDs.
Offline kattjaevel
Reply #12 on: February 21, 2020, 07:35:28 AM
No, the upper side of the 12AU7 still doesn't glow. That's what I tried explaining when I wrote that the filament doesn't glow. Probably incorrect terminology. This kit is very old if that adds to it. I bought it some 7-8 years ago.
T1 reads 145V,
T5 reads 92V
Reply #13 on: February 21, 2020, 09:19:05 AM
Inside the 12AU7 there are two plate structures.  Each plate structure has a heater that runs up the middle.  You may be able to see the bottom of each heater structure and/or the top of each heater structure.  If you can't see glowing dots on the top of each plate structure, then you need to look at the bottom of each plate structure to see if you have a glowing dot on each side.
If you have two glowing dots on the bottom of the tube, then that's useful information.  If you aren't sure, consider posting a photo of your tube glowing in a dark room.
Offline kattjaevel
Reply #14 on: February 21, 2020, 10:14:05 AM
Sorry Paul, I see how my response may be unclear. I see that the heater closest to the front of the chassis, the one that sits on top of A3, glows. But the one that sits on top of A8 doesn't.
« Last Edit: February 21, 2020, 11:17:13 AM by kattjaevel »
