CCS Loaded Parafeed Output - Design Considerations?
L0rdGwyn · 113963
Reply #180 on: April 23, 2021, 05:45:55 AM
Do you have a little bypass cap on the screen?  For the paralleled cathode followers, 1M seems like a reasonable grid leak choice.
Offline L0rdGwyn
Reply #181 on: April 23, 2021, 06:32:27 AM
Yeah I thought 1Meg was a good choice, I will leave it as is.  At the moment I do not have a bypass cap on the screen, I have seen it done both ways, got the idea from one of Pete Millett's amplifiers who left it unbypassed.  I tried it bypassed with 0.1uF and without, but did not see a measurable difference in gain, distortion, FR, etc.
« Last Edit: April 23, 2021, 07:41:02 AM by L0rdGwyn »
Keenan McKnight
Offline L0rdGwyn
Reply #182 on: April 23, 2021, 08:21:39 AM
Those test sockets are sweet. Nice flat frequency response !
And thanks, Thermioniclife!  Sorry didn't see your comment until just now.  The sockets are very nifty, sort of make the whole thing work.  I have some noval 9-pin boards as well that can be swapped in if the design calls for it, will use adapters for any oddball tube bases if need be.
Keenan McKnight
Reply #183 on: April 23, 2021, 06:04:40 PM
Your prototype board is way too neat, I'm sure that's your problem  ;)...John
Offline L0rdGwyn
Reply #184 on: April 24, 2021, 02:30:05 AM
HA!  That has to be it, no doubt.
I finished the second channel, the heater regulator I was also using as a bias supply was injectin HF noise into the EF37A grid, so I had to make a switch, nice and quiet now.  Maybe it was the tube swap, but the feedback and measurements improved in the final circuit, but HF extension, lower distortion and output impedance.
Output Z: 1.53ohm
Power: 6.2W into 8ohm
I had a listen with headphones, then lugged it into my stereo, the sound is very nice, will do some more tinkering of course but it won't be long before it is boxed.
Keenan McKnight
Reply #185 on: April 24, 2021, 06:03:36 AM
There are lots of 100-ish watt transmitting triodes, now you can go for 40W!
Offline L0rdGwyn
Reply #186 on: April 24, 2021, 02:49:22 PM
Oh man, scary to think about, but something tells me I'll mess with the 100W transmitters some day.
My next victim is the HK54, 15W single-ended, pretty good for 92dB/W speakers :D not sure when it will come to fruition, but have a nice protoboard to mess around with it now.
Keenan McKnight
Reply #187 on: April 24, 2021, 04:01:03 PM
Offline L0rdGwyn
Reply #188 on: April 24, 2021, 04:24:36 PM
HA!  Good one PB, I saw those while shopping for HK54, 100W with a 37.5W filament, woo boy!  I'm making my way there, 25W now, 50W next, then maybe the big fellas.  Getting ahead of myself but thinking of using EL34 to drive the HK54 grid.
Keenan McKnight
Reply #189 on: April 24, 2021, 04:32:35 PM
The EL34 isn't a bad choice.  Maximum cathode current is plenty high and high voltage isn't particularly bothersome.
Offline L0rdGwyn
Reply #190 on: April 25, 2021, 02:52:10 AM
I thought so too, took some measurements at a potential operating point, I found gm and linearity were better in the EL34 than say, parallel 6BX7 at high voltage, 440V B+.  Shouldn't have a problem with the 60mA grid current at peak swing, I have a pair of NOS EL34 burning a hole in my pocket too.
With a similar feedback circuit to the 801A design, the challenge is the gain.  For a 3K load to get 15W output with a 3:1 damping ratio with the HK54, will need something like 25dB of feedback.  I grabbed a couple of high-gain pentodes to try out, 6EW6 and 6AH6, the 6EW6 being the higher of the two.  With a 5-pack of NOS 6EW6, what I found was a high degree of variation in gm / the curves from sample to sample, even from the same exact batch, BUT they can be made to be matched pretty well by adjusting the screen voltage, so I would need an adjustable screen supply to match the feedback in both channels.
So we'll see, it's going to take some trial and error.
Keenan McKnight
Offline L0rdGwyn
Reply #191 on: May 22, 2021, 08:57:28 AM
I finished my 801A amp PB, here are some pics.
Keenan McKnight
Reply #192 on: May 22, 2021, 01:04:56 PM
Looks great!  How does it sound?
Offline L0rdGwyn
Reply #193 on: May 22, 2021, 01:09:08 PM
Really good, best of the amplifiers I have made so far, the real standout is the bass, unlocks a new level of potential from my Snells!  Great clarity and detail too, the speakers disappear.
Thanks for your $0.02 along the way.  First got the idea for an 801A build over a year ago now, figuring out how to make it happen was a serious learning experience.
Keenan McKnight
