Buzzing in Right Channel - Damaged Headphone Jack?[1]
jt23 · 2154
Offline jt23
[Apologies if this is a duplicate post, I got an error when trying to submit]
Hello,
In the past couple of days a buzzing/ringing noise has developed in the right channel of my amp. It's similar to the noise from cellphone interference, but more constant (I've tried turning off all phone/internet networks - no change) I've also plugged the power cable in different outlets etc. without differing results. I changed the headphone cables too, and have plugged the headphones into a different source with no issues; it's definitely in the amp.
The noise is present even without RCA inputs, and I've also tried cleaning the pins of both tubes plus swapping out the driver tube; no change.
I'm thinking it might be caused by a damaged headphone jack? - I clumsily bumped with my soldering iron when reheating joints a few weeks back.
I've attached a photo - is the best best just to buy a replacement jack?
Thanks for any advice,
Joel
Reply #1 on: March 25, 2020, 09:18:17 AM
This is unlikely to be the jack, but the solder joint where the black wires meet on the jack definitely could use a touch up.
The NYS212 is the replacement jack you need.  While you could normally get one from us, it's probably best if you ordered from a larger supplier based on what's currently going on right now if you want to get it in the next two weeks.
Offline jt23
Reply #2 on: March 25, 2020, 12:30:27 PM
Thanks PB - tried reheating the joint, no real change.
I noticed that there's a wire connected between the 3 outboard terminals of the jack, could this cause any problems? Another photo attached.
Noted re. the replacement part; I'll take a look if I can't seem to fix the issue.
Joel
Offline jt23
Reply #3 on: March 25, 2020, 01:06:10 PM
Also, it might be worth mentioning - the ringing noticeably decreases in amplitude when rotating the amp relative to sitting position.
Joel
Reply #4 on: March 25, 2020, 01:50:48 PM
The connection of the three outboard terminals is supposed to be there.  If you melt the jack enough, you could definitely lose a channel, but otherwise I wouldn't expect it to make much of a difference.
If you move the amp and things change, that indicates a bad solder joint or loose hardware.
Offline jt23
Reply #5 on: March 25, 2020, 02:11:31 PM
Okay! - I'll look into loose connections and bad solder joints then.
Joel
