Did I fry the headphone input? [resolved]
Discgo1013 · 4791
Offline Discgo1013
on: April 08, 2020, 03:20:32 PM
Greetings...used my home bound free time to complete a SEX kit I got over the holidays. Was fun to build and I had to resolder some of the headphone jack wiring and I think I may have fried the headphone input....I'm not a headphone listener but I have a cheap pair I've used for testing...I only get sound from the right channel with no phones plugged in, if I plug in just the tip of the jack I get sound from both left and right speakers
With phones if I plug the jack in all the way, I only get sound in the right, but if I back it out a click I get both channels.
Excuse this headphone newbie, its not a connection I'm used to...
Any insight here? Thanks in advance and hope everyone is safe & healthly
« Last Edit: April 25, 2020, 01:53:04 AM by Discgo1013 »
Reply #1 on: April 08, 2020, 03:23:17 PM
If you pull the headphone plug part way in, you will connect the tip and ring of the headphone jack to the tip of the headphone plug.
Do you get sound out of the left and right speaker posts?
Offline Discgo1013
Reply #2 on: April 08, 2020, 04:44:07 PM
Yes, I only get both left and right speaker channels audible with the headphone plug partially inserted, like 1 click....maybe it’s mis wired? The jack did get melted quite a bit when I resoldered, especially the middle terminals
Reply #3 on: April 08, 2020, 04:54:55 PM
If you use speakers on your amp, do you get sound from both sets of binding posts?
Can you post some photos of the jack?
How are your DC voltages?
Offline Discgo1013
Reply #4 on: April 09, 2020, 04:14:13 AM
Thanks for your help, Paul! Photos and DC voltage readings below, I did have a change from my original readings on terminal 16.
Quote
Only if I insert a headphone plug partially in, 1 click
No headphone cable plugged in: hear right speaker only
Headphone cable plugged in 1 click - hear both speakers
I've attached several photos of the headphone jack, after looking at the wiring with more attention, I think I may need to rewire the headphone jack to clean it up...think I should order a new one? Its melted a bit
2 - 80.8V
3 - 18.7V
4 - 12-15mV (this was 0)
5 - 0V
6 - 378V
7 - 398V
10 - 372V
16 - 54.5V (this was 78.2V)
17 - 17.9V
18 - 12-15mV (this was 0)
19 - 0V
20 - 377V
21 - 395V
24 - 369V
H2,H5 - 3.25V
H4, H7 - 3.08
Reply #5 on: April 09, 2020, 04:50:32 AM
Your headphone jack is a little melted.
Even with speakers, you can short the left and right channels by partially inserting a 1/4" plug, so that still doesn't tell us much.  If you horribly melted the jack, you might be able to only get both channels on your headphones, but not your speakers, and you'd see that the contacts that move when you plug in your headphones wouldn't touch with no 1/4" plug installed.
Your voltage on terminal 16 is a little off.
In the photo below, you can see what looks like a resistor lead poking out and going nowhere.  That is the kind of thing that will make your SEX amp not work, especially if it touches the chassis or the lead of another component.  If you have lots of untrimmed leads in your kit, you'll want to grab a proper pair of side cutters and trim them back.
Offline Discgo1013
Reply #6 on: April 09, 2020, 06:27:16 AM
Yea, I snipped that wire just after taking the photos, and before the voltage check..good catch
Any thoughts on where to look for the cause of low voltage on terminal 16?
What about bypassing the headphone output all together and attaching the green/brown wires from the output transformer to the RCA jacks directly instead of the headphone jack first?
I'm not a headphone user so don't need that functionality
Reply #7 on: April 09, 2020, 06:46:09 AM
See if the low voltage follows a tube if you swap them between channels.
I would very, very strongly not recommend modifying the amp in an attempt to solve a problem.  What you can do is with nothing plugged into the headphone jack, measure the DC resistance between:
1.  Each black binding post and the two lugs on the headphone jack closest to the chassis.
2.  The right channel red binding post and the two lugs on the headphone jack in the middle level (ring).
3.  The left channel red binding post and the two lugs on the headphone jack up top (tip).
Please post these measurements, then I can let you know if there's actually a problem with your headphone jack.  I am 99.999999999% sure that your headphone jack is working perfectly.
You might also want to post some photos of your build, as we may be able to spot something that is preventing the signal from leaving the amp on one channel.
Offline Discgo1013
Reply #8 on: April 09, 2020, 07:32:35 AM
Thanks for your support with doing things the right way! This is with the amp disconnected from power, correct?
Reply #9 on: April 09, 2020, 09:30:52 AM
Yes, it can be unplugged.
Offline Discgo1013
Reply #10 on: April 10, 2020, 01:40:23 AM
All resistance readings are 0, I guess this means the jack is fine?
Here's a photo of the entire build, I'm carefully checking each joint in the output wiring again now
Offline Discgo1013
Reply #11 on: April 10, 2020, 03:05:50 AM
Could this be a tube issue? I swapped R & L tubes and the issue follows the tube....I can still get both channels by partially inserting a 1/4 inch headphone plug
Its the same tube that gave the low Terminal 16 reading, got the same reading on Terminal 2 when I swapped them
Reply #12 on: April 10, 2020, 05:00:56 AM
Your resistance measurements indicate that the headphone jack is functioning 100% and you don't need to zero in on that to discover the source of your channel dropping.
Did the channel that's out follow the tube?
That just means you have one working channel.  This isn't really helpful information.
Immediately I noticed this piece of component lead circled in red.  If those two terminals touch, your SEX amp may turn into a smoke machine.
« Last Edit: April 10, 2020, 05:05:21 AM by Paul Birkeland »
Reply #13 on: April 10, 2020, 05:07:39 AM
If these leads in the red circles touch, you will lose a channel.
Offline Discgo1013
Reply #14 on: April 10, 2020, 06:39:01 AM
I need glasses and better light!
I'm having a real hard time seeing exactly what you've circled in the first photo in the amp...I felt comfortable during the build
Let me get some readers and better light and I'll try to sort this out. Thank you for your help and experienced eyes.
And yes, the channel that is out does follow the tube.
You rock, Paul!
