Eros build of a kit that has been waiting since 2015 makes it to pages 75 & 76
PaulG · 3240
Offline PaulG
I just got the kit all built and soldered with no leftover components and did the resistance check on pages 75 and 75 of the instruction.
Nearly all of the measurments are within the 10 to 15% range but there are a few that are about 20% higher than optimum in the instructions.
Terminal Strip
2. Should be 71K ohms.  It reads 85.5K with one meter and 83.4K with the other.
4. Should be 60k ohms.   It reads 75K with one meter and 73.3K with the other.
12. Should be 60K ohms.  It reads 74.9k with one meter and 72.8K with the other.
14. Should be 71K ohms.  It reads 85.3k with one meter and 83.8k with the other.
Nine pin sockets
A6. Should be 60K ohms.  It reads 75k on one meter and 73.3K on the other.
B6. Should be 60k ohms.  It reads 74.9k on one meter and 72.9K on the other.
C1. Spec is 39K ohms but it measures 46.7k
C2. Spec is 60k ohms.  It reads 75.1k on one meter and 73.6K on the other.
C6. Spec is 39K ohms but  it measures 46.6 ohms.
C7. Spec is 60K ohms.  It reads 75K on one meter and 73.1K on the other.
Is it okay to put the tubes in and go to the next set of measurements?  Visually it all looks right.
Interesting that A6 and B6 measure the same.
The meter that reads a little higher is a Klein Tools and the second readings are from an inexpensive Gardner Bender
Paul Grisanti
Gentleman of a certain age
built Heathkits in the late 1960's
built two Audio by VanAlstine kits in 1990
Yes, go ahead and move onto voltages.
Offline PaulG
Thank you for the encouragement.
Paul Grisanti
Offline PaulG
I went ahead an installed the tubes but neither of the russian V177 tubes that have 6x32 printed on them lit up.  The fuse is still good.
I think I screwed up by only being concerned about the measurements that were too strong and not just giving you all the measurements in the first place.
I re-examined the resistance figures and noticed the following differences between 9 pin Socket A and 9 pin Socket B: and what they are supposed to be doing.
Socket A        Socket B
pin 1  doesn' t wander  solid 0 measurement                                              very solid 26.95K
Pin 4  solid 618 ohm        very solid 623 ohm
Pin 6 75k Ohms not 60K        74.5k not 60K
on Socket C, which did light the tube up, the following readings are out of spec.
Pin 1 46.7k Ohms, not 39k
Pin 2 75k ohms, not 60k
pin 3 0
pin 4 a very steady .618k ohms  not infinity
pin 6 46.6k ohms, not the 39k specified
pin 7 measures 74k ohms, not 60K ohms
pin 8 doesn't wander but is a steady 26.93k
All of the LEDS were lit but with the two tubes not lit but only the BA voltages are correct .
Thinking I should declare victory, box this up and send it in.
Paul Grisanti
How about posting your voltage measurements?
Offline PaulG
I guess that would be a lot more helpful than pouting about the fact that I've screwed up!
These are the voltages as we work our way clockwise around the left half of the photo on page 77 of the manual starting from the left C4S board
Location           Specification      Actual
Kreg                approx 1VDC      107.5mV it climbed very slowly
breg                 100 VDC            0
OA                   170 VDC            8.94 VDC
IA                    225 VDC            222.8 VDC
bA                    0 VDC               0 VDC
OB                   100 VDC            2.24 VDC
Right half of the photo starting from lower right of the right C4s board
Kreg                approx 1 VDC     1.6 VDC
breg                100 VDC            98.4 VDC
OA                  170 VDC            168.5 VDC
IA                   225 VDC            222.5 VDC
bA                   0 VDC               0
OB                  100 VDC            96.5 VDC
I will swap the tubes in the A and B sockets and see if that changes the measurements.
Paul Grisanti
Offline PaulG
Changing the Russian tubes from side to side had no effect on any of the voltages.
Paul Grisanti
I would be interested in seeing some build photos.
One side of your Eros at least is working properly.
Offline PaulG
These are pictures of the left C4S board.
Paul Grisanti
Offline PaulG
More pictures
Paul Grisanti
Offline PaulG
last photo batch
Paul Grisanti
If the leads in the red circles touch, things will go very south in a hurry.
Offline PaulG
In 3 d space the wire in the last pic have a reasonable amount of clearance.
Paul Grisanti
Offline PaulG
Must be time to dismount the left C4S board.
Paul Grisanti
Well, you have a working board and a non working board.  You can pull each C4S board out and move it to the opposite channel to see if the issues move with the board, or you can reflow all the joints on the offending side and see if you notice any differences in the wiring/installation.
