Shunt regulator test failed
arisrock · 3447
Reply #15 on: April 30, 2020, 11:34:14 AM
Can you post some fresh photos?
Offline arisrock
Reply #16 on: April 30, 2020, 11:55:47 AM
SOLVED.. Ok, so this is the dummest. But.. It seems I was measuring the wrong thing, Instead of putting the "-" Voltometer terminal at the Ground of Eros, I put it at 31U instead, and measured 217V at the terminals, as it should measure. So everything was working all along, but I was measuring the wrong thing....
Reply #17 on: April 30, 2020, 12:06:15 PM
Well, you have done a lot of inspection on your work and you can have some additional confidence that all is well ^_^.
