S.E.X. amp seconde hand
mwgrient · 13108
0 Members and 4 Guests are viewing this topic.
Online Paul Birkeland
Reply #60 on: May 30, 2020, 08:11:11 AM
Then the resistor at A6 would be broken or loose.
Offline mwgrient
Reply #61 on: May 30, 2020, 08:55:57 AM
would like to check something before:
in de manual 2.1 - (the amp is a 2.1 S.E.X. amp) the attachment states something different than my amp. See my picture. Or is this because of the C4S module?
I will take a look at the manual for resitance checks. It looks different on the picture too.
Reply #62 on: May 30, 2020, 09:07:38 AM
That's the part replaced by the C4S.
Offline mwgrient
Reply #63 on: May 30, 2020, 09:26:08 AM
 :-) Thank you!
Offline mwgrient
Reply #64 on: May 30, 2020, 10:02:45 PM
Messurements, resistance check.
Terminal  -   Resistance
1 - *
2 - 0
3 - 0
4 - *
5 - *
6,16 - *
7,17 - 0
8,18 - 0
9,19 - 245
10,20 - *
11,21 - *
13,23 - 0
14,24 - 093 / 089
15,25 - 890 / 890
A1,B1 -  245 /  245
A2, B2 - *
A3, B3 - 0 / 0
A4,B4 *
A5,B5 - 678 / 678
A6,B6 - 1 / 1
A7,B7 - 6 / 6
A8,B8 6 / 6
C
1,C2,C4,C5 *
What do you think about it?
I have to lookup the part/value and buy the resistance online (for a6), like you earlier suggested).
« Last Edit: May 30, 2020, 11:33:29 PM by mwgrient »
Offline mwgrient
Reply #65 on: May 30, 2020, 11:54:01 PM
Reply #66 on: May 31, 2020, 05:42:10 AM
Those resistances look like maybe the meter isn't on a range that will adequately resolve the resistor values all that well.  You can use your meter to measure the 1.27K resistor, does it measure 1.27K?
The idea that you need to run out and buy new parts to replace all the parts in your SEX amp will create more problems than it will solve.  It's important to figure out what's actually not working, then fix that.  If you make guesses and start replacing parts at random, you will very likely make more operational problems than you had before.
Offline mwgrient
Reply #67 on: May 31, 2020, 06:31:34 AM
I can not say I am knowing what I am doing.  :) - thanks for your guidance en tips! Much appreciated!
The resistance measure (with meter on 20k ohm) both: 1.24
Reply #68 on: May 31, 2020, 06:46:29 AM
OK, so there's no need to replace a resistor that reads the proper resistance.
You had 0V across this part, then 9V across this part.   This is indicative of loose parts or a broken wire in the amp.
Offline mwgrient
Reply #69 on: May 31, 2020, 08:21:56 AM
I do get some weird measurements on terminals:
10 - 20 --> 208 - 410 (so, 20 looks OK, nut 10 is surly low on voltage).
If you would like to see all the measurements, I can post them of course.
Offline mwgrient
Reply #70 on: May 31, 2020, 09:17:19 AM
Nevermind, desoldered the joint, now it's OK.
Right channel is still off.
Offline mwgrient
Reply #71 on: May 31, 2020, 09:55:18 AM
Also, saw that te LEDs on the C4S, are 2x bright and 2x low or not so bright. See picture. Maybe an indication.
Reply #72 on: May 31, 2020, 11:07:52 AM
Yes, it's an indication that you have a broken wire or a loose connection on that side of the amp.
Offline mwgrient
Reply #73 on: May 31, 2020, 11:40:04 PM
When I touched it, one leg broke. It was on the right side. I truly hope that this was my trouble maker... So I have bought a new set and wait for delivery.
Reply #74 on: June 01, 2020, 06:06:03 AM
That part can be 100% out of the circuit and the DC voltages will still be correct.
