Faint 60-Cycle Hum
jtori · 16332
Reply #15 on: June 29, 2020, 09:39:34 AM
Yes.  When the coarse and fine are all the way up, it's noisiest.  I will do as you've suggested.
But if fine is all the way up and coarse is all the way down, it's still quiet?
Offline jtori
Reply #16 on: June 29, 2020, 10:09:56 AM
Not present, or very, very faint.
Offline jtori
Reply #17 on: June 29, 2020, 12:57:50 PM
Followed Paul's and Deke's guidance and desoldered at all the points on TwoQuiet where black leads land.  These connections are now clean.  With no signal, hum is nearly inaudible until -9dB on the coarse attenuator, where it becomes audible.  At 0dB, it is as before.  So, not sure where to go from here.  I defer the the sage wisdom of the most august members of this forum.  :)
Reply #18 on: June 29, 2020, 01:06:31 PM
Is this still with shorted inputs?
Offline jtori
Reply #19 on: June 29, 2020, 01:59:07 PM
No.  Dead quiet with inputs shorted.
Reply #20 on: June 29, 2020, 02:28:40 PM
Then your amp is working properly.
