voltage discrepancy OA/OB
denti alligator · 4626
Reply #15 on: June 29, 2020, 06:22:13 AM
You should also swap both the input and output cables at the same time to rule out that you have a flaky cable.
Offline denti alligator
Reply #16 on: June 29, 2020, 08:43:15 AM
OK, I went over every joint, including removing the PC boards to get under them and reflowing the underside of each board. Same readings and same off-center sound. Is it time to send it in?
- Sam
Reply #17 on: June 29, 2020, 08:50:51 AM
Please be sure this isn't just a cable issue.  All of the Eros 2 kits that I have received for repair so far have been working perfectly.
Reply #18 on: June 29, 2020, 08:55:46 AM
I'll double check, but these are the same cables that were plugged into my Seduction, which worked fine.
I switched the input and output cables. Same problem. I'll try another set to be sure.
- Sam
