Paramount 300B hum balance adjustment
Anton · 32824
Online Paul Joppa
Reply #15 on: July 02, 2020, 05:49:20 AM
As tubes age, some mechanical warping takes place (as I understand it, typically the filament) due to the number of heating/cooling cycles. Since these tubes are well used, it is reasonable to guess that's the reason for the modest change in hum level.
Here's a little background: The design goal was 2mV, which is quiet enough for all but the most efficient all-horn speakers. Without the DC filament supply, I was not able to get hum below 5-8mV. If the hum is a problem, an electrolytic capacitor can be installed at the output of the filament supply to reduce it further. We didn't include that in the stock amp in the interest of avoiding capacitors in the filament supply, which some listeners think are responsible for a "flattening" of the sound. I find it to be a very subtle difference, but YMMV - we all hear a little differently.
In the current Stereomour and Kaiju, we have separated the DC filament supply as upgrade kits, since for most speakers even 5mV is good enough to be inaudible.
Offline Gerry E.
Reply #16 on: July 02, 2020, 09:50:14 AM
Hi:
This thread motivated me to measure the hum on my Paramounts.  Using the same page 64 procedure as above, with and without a load, I can dial in .000v on both amps.  Is that possible?  The meter is an inexpensive Radio Shack auto range unit but it has worked well over the years.  My speaker sensitivity is approx. 95dB and I hear almost no hum with my ear to the speaker drivers.
Gerry
Reply #17 on: July 02, 2020, 10:05:39 AM
0.000V tells you it's less than 1mV, which is generally what I have measured on Paramounts (about 600uV).
Offline Anton
Reply #18 on: July 02, 2020, 04:30:24 PM
Hi:
Gerry
Hi Gerry,
Do you have a standard version of the Paramounts or the one with the soft start upgrade?
Eros phono / Foreplay III extended upgrade / Paramount 300B/ S.E.X. 2.1 impedance switch upgrade
Offline Gerry E.
Reply #19 on: July 04, 2020, 09:45:18 AM
Hi Gerry,
Hi Anton:
Soft Start v1.1.
Gerry
Offline Anton
Reply #20 on: July 04, 2020, 03:57:31 PM
Hi Anton:
Soft Start v1.1.
Gerry
Thank you Gerry, and Happy 4th of July!
I wonder whether soft start upgrade would affect the hum level?
Reply #21 on: July 04, 2020, 04:09:41 PM
No.
Offline Anton
Reply #22 on: July 05, 2020, 12:29:20 PM
