Should upgrades be done in any particular order?
Twodawgzz · 2721
Offline Twodawgzz
on: August 05, 2020, 08:01:19 AM
I have the DC Filament Supply, Shunt Regulator, and MourQuiet Attenuator upgrades to install.
Does it matter which one I work on first?
Reply #1 on: August 05, 2020, 08:16:15 AM
The absolute most important thing is that you build the amp stock first and getting it 100% working.  It's far harder to debug an amp with upgrades when you don't know whether it's the upgrades or the stock build that caused the issue.
I would put the DC filament in first, because it's far easier than the other two upgrades.  I would do the SR driver next, then the attenuator last, mostly because you'll be well warmed up by then and you want to do your best work on that attenuator.
Offline Twodawgzz
Reply #2 on: August 05, 2020, 11:42:52 AM
Thanks Paul.
