Chassis plate dxf
lina · 3141
Offline lina
on: August 14, 2020, 08:32:09 PM
I see some old threads that ask for/mention chassis plate dxf files, but can't find a conclusive yes or no about the availability of one. I'm considering getting a brass plate laser cut to use instead of the aluminum stock plate. Any chance there's a dxf/etc file I can get for that?
Online Doc B.
Reply #1 on: August 15, 2020, 01:58:30 PM
We don't share our chassis panel CAD files. But it's not that hard to measure a panel and create your own.
Offline lina
Reply #2 on: August 15, 2020, 04:31:56 PM
Ah, oh well. To the CAD!  ;D
I've also got a dumb question... does the safety ground lug's design do something special, or would it be fine to just solder a lug directly to the chassis' underside? Figure that if I'm gonna design my own plate, I may do away with (or hide) some of the visible screws.
Reply #3 on: August 16, 2020, 07:09:26 AM
If you think you can solder well to the brass, then you could certainly do that.  If I made a brass plate, I would want to put a clear coat over the whole plate to keep it looking nice, and the effort of soldering to the plate may cook that right off.
Online Paul Joppa
Reply #4 on: August 16, 2020, 09:41:54 AM
For safety reasons, the safety ground wire should stay connected to the plate under violent accidents that would disconnect other wiring. That's why it has its own terminal and a tight screw holding it in place. Solder connections are nowhere near as strong as screws.
Offline grufti
Reply #5 on: August 16, 2020, 10:39:49 AM
You could use a screwed on sub-plate below the decorative brass one - four screws, one in every corner. You would still attach some parts directly to the brass plate, connectors for example. That way you can still maintain the original layout and have your clean look. It gets more complicated than a straight up build.
Reply #6 on: August 16, 2020, 04:04:15 PM
I don't know, reworking vintage amps that solder to the chassis is a total PITA.  Those are the most difficult connections to remove!
Reply #7 on: August 16, 2020, 11:13:11 PM
I know strictly speaking an earth bonding should be a dedicated stud/bolt, however you are going to have to bolt the mains transformer to the chassis anyway, so why not use one of those fixing for the earth bonding?
Offline Natural Sound
Reply #8 on: August 17, 2020, 04:01:31 AM
I say drill the hole and leave it as designed. One more screw head towards the rear of the chassis isnt going to change the esthetics one bit IMHO. Defeating engineered safety measures is never a good idea either.
Offline lina
Reply #9 on: August 17, 2020, 07:47:13 AM
Yeah, I realized that was an option as well, and I'll likely go with that (maybe even solder the lug over the hole just to be extra safe, if I wanna be paranoid about it). Thanks for the responses folks, good things to think about. Just in case I decide to solder to the brass chassis at all, I'll first get a sample plate to test solder strength & see if it burns away lacquer finish in a bad way and whatnot (as Paul B mentioned).
Another question... would it be possible or a bad idea to use a switching jack in place of the power switch? Looking for a switch that fits the design I'm going for but not finding any I'm too thrilled with... figured maybe I could just do that and unplug the headphones to turn the kit "off". If it's not a bad idea to do so, any caveats I should consider?
« Last Edit: August 17, 2020, 07:56:36 AM by lina »
Reply #10 on: August 17, 2020, 07:52:04 AM
I don't think I've seen a switching headphone jack that will switch mains voltage.
Offline lina
Reply #11 on: August 17, 2020, 07:57:30 AM
Ah, righto. Figured that was likely the case but thought I might as well ask, thanks.
Reply #12 on: August 17, 2020, 07:59:54 AM
Even if such switch exists, do you really want 60Hz mains power a fraction of an inch from your output signal wiring? Seems to me like a recipe for hum. Or if the switch has tons of shielding it will be be huge and very pricey.
cheers, Derek
Offline lina
Reply #13 on: August 17, 2020, 08:05:02 AM
True true. Yup, not a good idea even if it was possible.  :P
Online Paul Joppa
Reply #14 on: August 17, 2020, 08:17:35 AM
The separate mounting bold for safety ground is explicitly called out as a requirement in the UL safety rules. These rules are primarily based on actual injuries that have happened in the past, not just things that might theoretically happen.
