voltage check reduction new reduction build [resolved]
lesouthern · 20620
Offline lesouthern
on: September 20, 2020, 06:47:45 AM
Hi-
Just did voltage check- seems I have an issue with terminal 2- what terminals should I be checking, and what should I be checking for?
thanks
Larry
Terminal   Voltage      Expected
1      0      0
2      151      70-90
3      0      0
4      151      145-155
5      0      0
6      0      0
7      74      70-90
7      74      70-90
8      0      0
9      0      0
10      0      0
11      0      0
12      0      0
13      72      70-90
14      72      70-90
15      71      70-90
16      0      0
17      0      0
18      67      70-90
19      67      70-90
20      67      70-90
21      0      0
22      0      0
23      1-2      0
24      0      0
25      0      0
26      67      70-90
27      0      0
28      0      0
29      151      145-155
30      0      0
31      85      70-90
32      0      0
33      5.9      6
34      0      0
35      0      0
36      0      0
37      5.9      6
38      10.4      10-11
39      4.1      4-5
40      0      0
41      4      4-5
42      10      10-11
43      0      0
44      77      0
45      77      0
46      0      0
47      177      180
48      0      0
49      0      0
50      164      165
51      164      165
52      177      180
53      177      180
54      0      0
55      0      0
56      151      145-155
57      151      145-155
58      0      0
59      164      165
60      164      165
61      0      0
62      0      0
« Last Edit: September 21, 2020, 07:07:15 AM by Paul Birkeland »
Reply #1 on: September 20, 2020, 07:06:40 AM
I would post some photos of your build.  I'm guessing you have one LED that isn't lighting.  Typically what I find when I get Reductions in for repair with this issue is a loose ground connection.  You can poke at the circuit with a wooden chopstick while it's running (not hooked up to anything though!) and I would bet that when you poke the loose connection, the LED that isn't lit up will light up.
Offline lesouthern
Reply #2 on: September 20, 2020, 12:06:09 PM
Hi Paul,
The light connected to A3 was flashing. I resoldered 11L, and now voltagef on terminal 2 is normal at 70
Now that the voltage was normal, I plugged it in and am getting humming.
Attached are pictures of my build. This is my first project, and electrical in general. Tried to follow suggestions but am sure my soldering will not win any awards.. be kind :-)
thanks
Larry
Reply #3 on: September 20, 2020, 12:22:28 PM
What do you have hooked up to the inputs?  Do you have the tonearm ground wire hooked up to the ground post? Is it humming from both channels?
Offline lesouthern
Reply #4 on: September 20, 2020, 12:38:04 PM
The humming is only coming from the B, black, left side.
I'm plugging this into a Rega Planar 2, the ground is supposed to be in the black side cable- there is no ground.
Also I notice the issue is only when I plug in the turntable
Reply #5 on: September 20, 2020, 12:43:10 PM
Are you 100% certain you have the RCA jack hardware in the proper order?  I've seen this kind of situation pop up when the hardware on the RCA jacks is left in the same order it comes in from the factory, which isn't correct.
Offline lesouthern
Reply #6 on: September 20, 2020, 01:14:44 PM
I've been using the P2 on the phono stage of my 1976 JVC JA-S31 for about a year, no hum with the cables in the correct sided RCA connections on the amp side.
I hear the hum on this amp if I don't have the black side connected.
For grins I tried switching the turntable cables on the Reduction, red to black, black to red, still have a hum
For all this I think the turntable is setup correctly. I would have to open the tone arm to do this? See picture.
Tried connecting Reduction to my Schiit Magni, still have hum
Pictures of my setup...
Offline lesouthern
Reply #7 on: September 20, 2020, 01:43:59 PM
I've also tried connecting the Reduction to my audio technica, with the phono stage switched on. that has a ground connection that I connected. Still getting hum
Offline oguinn
Reply #8 on: September 20, 2020, 01:53:48 PM
He’s suggesting the RCA Jack hardware is improperly installed on the amp, I think. Maybe review the RCA jacks and make sure they have the washers and nuts installed as the manual says, which is different than how they come out of the package.
Jameson O'Guinn
Offline lesouthern
Reply #9 on: September 20, 2020, 02:24:33 PM
I connected Reduction straight to my Schiit Magni, with the P2 also getting hum...
Think I have a build issue, but not sure where to start looking
Reply #10 on: September 20, 2020, 03:01:41 PM
Yes, this.  The correct order is shown on page 13.
Offline lesouthern
Reply #11 on: September 20, 2020, 05:10:45 PM
I see exactly what you mean.
Printing out the manual lowers the resolution of these images. I totally missed that until I looked at the digital version
thanks much
Offline lesouthern
Reply #12 on: September 20, 2020, 06:41:48 PM
Paul-
I'm looking at the front page of the manual, at the RCA tabs. The washers next to the body are all white.
Are these supposed to be the black and red colored washers that come in the kit?
If so could you please send me a closeup picture of the topside of these RCA connectors?
I want to triple check I'm doing this right
thanks
Larry
Reply #13 on: September 20, 2020, 07:40:00 PM
I would suggest reading the text in the manual, as it calls this all out very specifically.  The color of the washers isn't important (the photo is of the jack we used to use).  The order is very clearly laid out and the photo on the top right of the screen grab I posted shows the jacks we provide currently.
Offline lesouthern
Reply #14 on: September 21, 2020, 06:54:09 AM
Thanks much for the support and patience with this newbie! Corrected the connections and that fixed the issue.
Have a successful Reduction build now. On to the Crack.
