Bottlehead Kits
Crack
Resolved - voltage check failing (low)
Gizmo1k
1662
Gizmo1k
Newbie
October 31, 2020, 08:41:04 PM
my voltage check is off some of the values are low wondering if anyone has good stuff to check, resistance test works and glow test worked also.
1.24
2.67
3.0
4.67
5.46
6.0
7.18
8.0
9.49
10.0
Last Edit: November 01, 2020, 05:00:04 AM by Gizmo1k
Paul Birkeland
Global Moderator
Hero Member
Re: voltage check failing (low)
Reply #1 on:
November 01, 2020, 04:25:10 AM
Can we see some photos of your build?
What was your measured AC mains voltage? What did you wire the amp for? Where do you live?
What kind of meter are you using? If you try to measure a fresh 9V battery, what DC voltage does it show?
Guest
Reply #2 on:
November 01, 2020, 04:38:21 AM
And make sure you have the meter set to measure DC voltage, not AC voltage. The DC symbol is usually two parallel horizontal lines, one dashed and the other solid.
cheers, Derek
Gizmo1k
Newbie
Reply #3 on:
November 01, 2020, 04:58:51 AM
Resolved. Thanks guys. First time through I didn’t have set to dc then I got that going. Turns out I had the cap on pins 6-7 backwards. And had a bridge on the 9 pin tube. It’s up and running thanks
Bottlehead Kits
Crack
