Resolved - voltage check failing (low)
Gizmo1k · 1666
Offline Gizmo1k
on: October 31, 2020, 08:41:04 PM
my voltage check is off some of the values are low wondering if anyone has good stuff to check, resistance test works and glow test worked also.
1.24
2.67
3.0
4.67
5.46
6.0
7.18
8.0
9.49
10.0
« Last Edit: November 01, 2020, 05:00:04 AM by Gizmo1k »
Reply #1 on: November 01, 2020, 04:25:10 AM
Can we see some photos of your build?
What was your measured AC mains voltage?  What did you wire the amp for?  Where do you live?
What kind of meter are you using?  If you try to measure a fresh 9V battery, what DC voltage does it show?
Reply #2 on: November 01, 2020, 04:38:21 AM
And make sure you have the meter set to measure DC voltage, not AC voltage. The DC symbol is usually two parallel horizontal lines, one dashed and the other solid.
cheers, Derek
Offline Gizmo1k
Reply #3 on: November 01, 2020, 04:58:51 AM
Resolved. Thanks guys. First time through I didn’t have set to dc then I got that going. Turns out I had the cap on pins 6-7 backwards. And had a bridge on the 9 pin tube. It’s up and running thanks
