7C5 Tubes in Moreplay
Cary · 6581
Offline Cary
on: November 24, 2020, 06:50:02 AM
Another tube that can be used in the Moreplay is the 7C5 Loctal Tube. I purchased a pair of 7C5 to 6V6 adapters from eBay, and just received a pair of RCA 7C5's yesterday. 7C5 tubes are 6V6 in Loctal configuration. For those of you who love to roll tubes this opens up quite a few options, 7C5 tubes are very affordable and easy to source.
Reply #1 on: November 24, 2020, 06:56:56 AM
How are they sounding?
One could also use the 6AQ5 in the Moreplay, in fact the first prototype I built uses them.
Offline Cary
Reply #2 on: November 24, 2020, 07:03:08 AM
Hi Paul,
They sound great, at the moment I only have three hours on them. Thanks for the info that the 6AQ5's can be used, a friend gave me seventy JAN 6AQ5's. After I get sixty hours on then I will report back.
Wishing you and your family a great Thanksgiving.
Cary
Offline Tubegopher
  • Don Palmer
Reply #3 on: November 24, 2020, 07:18:35 AM
Paul, I probably have about a dozen 7C5 tubes. Let me know if you would like a few. I do not however have any loctal sockets.
Have a great time with your family this Thanksgiving.
Don
Reply #4 on: November 24, 2020, 09:58:58 AM
I have lots of extra local sockets, I'm happy to trade!
Offline Cary
Reply #5 on: November 25, 2020, 04:50:59 AM
Paul,
Can the 6CM6 be used since it’s part of the 6V6 family?
Thank you,
Cary
Reply #6 on: November 25, 2020, 06:13:42 AM
Sure, if you can find an adapter or wire in a 9 pin socket, it should work nicely.
Offline Cary
Reply #7 on: November 25, 2020, 06:37:01 AM
Thank you Paul, I found a 6CM6 to 6V6 adapter on eBay.
Cary
Offline Cary
Reply #8 on: December 18, 2020, 07:57:32 AM
I now have over sixty hours on my 7C5 tubes. Compared to the supplied 6V6 tubes the 7C5's sound cleaner, well defined bass, great highs and a fantastic midrange. Lets talk costs, 7C5 to 6V6 adapters are ten dollars each, 7C5 tubes are ten dollars each. One thing that I recommend is to clean the pins of the tubes. I use a brass wire brush on my Foredom tool(an industrial grade Dremel tool). As I have stated the 7C5 is a 6V6 tube in Local form.
Wishing everyone happy holidays!
